Break-thru: Reading ACD ECU with EcuFlash
Old Mar 4, 2010 | 03:36 AM
  #166
_Speedy_'s Avatar
Originally Posted by Ceddy
Does anyone know if EvoScan's AYC logging works correctly for the ACD also?
Yeah v2.7 now has ACD and AYC and TCU in the dropdown.
Old Mar 4, 2010 | 03:43 AM
  #167
rolly1818's Avatar
Registered User
Originally Posted by _speedy_
yeah v2.7 now has acd and ayc and tcu in the dropdown.
tcu?
Old Mar 4, 2010 | 03:51 AM
  #168
_Speedy_'s Avatar
I think its automatic transmission control unit
Old Mar 10, 2010 | 04:54 PM
  #169
merlin.oz's Avatar
ceddy or logic, any progress with the disassembly and map investigations?
acamus, can the baud rate / sample rate of your scanner be increased?
It all seems to work OK, just a bit slow, or can I change some setting?
and finally, does anyone know if Hamish has fixed the out of range error in v2.7 beta?
Old Mar 10, 2010 | 09:50 PM
  #170
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
After looking at the Technical Manual, it appears that the x-axis for Table Main and Table C is most likely Steering Angle.
A optical wheel is used, with three outputs. I think they time the difference between leading edges of the waveforms. Zero difference would be steering wheel neutral, and a large time difference would be the steering wheel turned a lot.
Some real world data will be needed to find the scaling, as I have no idea what the frequency of the waveforms and the ecu timer is.
Definition Update
Main -> Steering Angle x Vehicle Speed
Table A -> Throttle Position x Vehicle Speed
Table B -> Front/Rear Speed Difference x Vehicle Speed
Table C -> Steering Angle x Vehicle Speed
Just need to find what .1, .2, .3 correspond to, Snow, Gravel, Tarmac.
And the definition will be fairly complete.
-> yes, but it is not worth the effort as EvoScan has already the AYC/ACD in
-> no, it is just testing application
Old Mar 11, 2010 | 06:23 AM
  #171
griceiv's Avatar
2 of the wires in the steering position sensor are the quadrature outputs for an incremental rotary encoder signal and the 3rd indicates when the wheel is on center.
http://en.wikipedia.org/wiki/Rotary_encoder
Old Mar 12, 2010 | 08:07 PM
  #172
Ceddy's Avatar
I think we are waiting for a update to EcuFlash so it can flash all the blocks in the ACD.
Then we can log items from a custom MUT table. This will enable us to figure out which maps are Tarmac, Gravel, Snow, etc.
My disassembly has hit a wall until I can get some logs with custom items from someone.
Old Mar 12, 2010 | 09:23 PM
  #173
R/TErnie's Avatar
props guys. You all rock.
Old Mar 25, 2010 | 05:49 PM
  #174
colby's Avatar
Can someone give me some specifics of what blocks / data they are having trouble flashing? I have done some test writes in various empty areas of the ROM on a Evo8 ACD and haven't run into any problems. If someone can send me some ROM images with changes that they are having trouble flashing, that would be helpful. (support@tactrix.com).
Colby
Old Mar 25, 2010 | 06:48 PM
  #175
Ceddy's Avatar
Think there were issues with trying to edit the MUT Table.
0x3316-33F8 in 401403 ACD ROM.
sba or Acamus will hopefully chime in or send you a ROM.
Old Mar 25, 2010 | 10:56 PM
  #176
acamus's Avatar
Post
Colby
That is a great news as we were not able to flash anything with OP2.0.
Maybe we just do not know what shall be in xml def header?
We have been using
Code:
                <flashmethod>mitsukernel</flashmethod>
		<memmodel>H8539FA</memmodel>
Could you make a dropdown list of kernels/processors/memory models when creating definition in EcuFlash?
Old Mar 25, 2010 | 11:02 PM
  #177
merlin.oz's Avatar
^colby, you have mail x2
Old Mar 26, 2010 | 05:56 AM
  #178
sba's Avatar
sba
Hello boys,
It is some time of being absent from here but i was very very busy.
I can post some files with 2 readings of a blocked ecu and a file that i tried to right it and blocked the ecu. I got ecu blocked when i tried to modify mut table also.
So, in the zip you will find the original file from the ecu, the file that i wanted to right and the 2 readings with errors.
File Type: zip
Old Mar 26, 2010 | 05:57 AM
  #179
sba's Avatar
sba
Oh, and one more thing: is the EvoScan released even for beta-testing with this ecus?
I didn't had any answer from Hamish for some time.
Old Mar 26, 2010 | 01:42 PM
  #180
colby's Avatar
OK. I have the kernel problem fixed now. I will be releasing a new beta version on www.tactrix.com later today that will have the fix. H8539FA is the correct memory model. Let me know if you have some reasonable definitions for the ACD, and I will add those XMLs to EcuFlash if you would like. I have already added the ACD as a read option.
Colby
We have been using
Code:
