Break-thru: Reading ACD ECU with EcuFlash
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Here is a pinout,
I guess some of not connected pins serves as reflash pin.
Can anyone confirm if the G-Sensors (EVO X ACD) are actually inside the ACD ECU box?
I have actually relocated the mounting of my ACD ECU and find I am not getting the results I am expecting when swapping the Ralliart ACD ECU in my rally car.
I'd be interested to know a little more about all this, if someone can chime in, maybe even Colby.
[17:01:42.921] flashing tool "mitsubootloader" loaded.
[17:01:42.921] flashing tool "shbootmode" loaded.
[17:01:42.921] flashing tool "shaudmode" loaded.
[17:01:42.921] flashing tool "hondacan" loaded.
shbootmode i know about it, for the SH processors from Subaru Ecus.
I'd like to know if misubootloader can be also used simillar to shbootmode?
And what are the other 2?
EvoScan v2.7.0090 can now successfully ACTUATE AYC Air Bleed and ACD Air BLEED options for Evo7/8/9.
in EvoScan v2.8 I'm gonna increase the logging support for the ACD/AYC (and is it true that its actually a shared ecu in the evo7/8/9?) so in EvoScan only select AYC for Evo4/5/6 and select ACD for Evo7/8/9 ACD/AYC.
I also updated the tech info website with your pinouts Acamus, looks great: http://www.evoscan.com/technical-veh...cd-ayc-sayc-at
great new ! thanks a lot for this usefull feature - will test it soon
regarding the ACD/AYC : yes the ACD and AYC on 7/8/ share the same ecu (and hydraulic pump)
Thanks!
Dan
