Break-thru: Reading ACD ECU with EcuFlash
Old Oct 2, 2010 | 06:55 AM
  #376
lan_evo_mr9's Avatar
Here's the complete rom info off my ACD unit. I believe I should be able to convert this ROM to 401403 yes?
Attached Thumbnails Break-thru: Reading ACD ECU with EcuFlash-acd-rom-info.png
Old Oct 2, 2010 | 04:14 PM
  #377
VGergo's Avatar
Can i help on this project ? I'm from Europe Hungary. We have some Evo 6 TME, Evo 8 EDM, Evo 9 JDM, maybe evo 9 EDM and Evo X EDM too. I can try to read out the rom. Also a lot of rally team are here with standalone Motec, Pectel Ecu in evo 6 and evo 9. If it is help maybe I can get logs. Lot of people will happy If we can tune the system without expensive after market ecus.
Old Oct 3, 2010 | 10:56 AM
  #378
Dragon-V's Avatar
Can you save the ROM and email it to me ?
You should be able to convert over, but make sure you save the old rom.
Old Oct 3, 2010 | 01:28 PM
  #379
No problem . I'll get it off to ya later tonight or tomorrow at some point.
Is there a point of saving it even though no tables show up? As you can see, it's completely "empty". The reason I'm thinking the 401403 rom would work is because they're both evo8 and labeled as 2004. Just a guess though.
Old Oct 4, 2010 | 02:14 PM
  #380
leecavturbo's Avatar
once the xml is correct for that rom then the tables will show
Old Oct 4, 2010 | 03:15 PM
  #381
Yeah, but I was wondering if the rom's were "standardized" like the ecu roms. I read earlier in this thread that different roms can be flashed to different ACD units, but I just want to make sure before I fudge anything up.
Old Oct 10, 2010 | 12:53 AM
  #382
evonut270's Avatar
where abouts in hungary are you?
Old Oct 18, 2010 | 03:41 AM
  #383
VGergo's Avatar
I'm in Budapest
Old Oct 22, 2010 | 05:36 AM
  #384
Minde_Kei's Avatar
hi,
i am from Lithuania, in Europe. I have acceses to few different USDM Evos, VIIIs and IXs. I have also Rallyart Rally Gravel ACD ecu. So if somehow i can help to make ACD flashable, editable - please let me know.
I know many rally teams/drivers here, and I think i could be able to get GEMS/Motec/Pectel ACD roms/maps for gravel mainly, because tarmac is not populare here.
cheers,
Mindaugas
Cheers, Mindaugas
Old Oct 22, 2010 | 10:16 PM
  #385
Originally Posted by Minde_Kei
hi,
cheers,
Mindaugas
Cheers, Mindaugas
It would be excellent to see what the engineers did with the advanced mapping of ACD. Any posting of Ralliart maps would be interesting to see compared to some of the professionally tuned roms and stock roms. Read away my friend
Old Oct 23, 2010 | 07:16 AM
  #386
evonut270's Avatar
I'm in Budapest
im currently in vienna. i dropped you a pm
Old Oct 24, 2010 | 10:24 PM
  #387
fostytou's Avatar
EvoM Community Team
hi,
cheers,
Mindaugas
Cheers, Mindaugas
It would be great if we could get those to compare against the factory tune. Are they built on the same hardware architecture as the USDM OEM ACD?
Old Dec 29, 2010 | 08:17 PM
  #388
djdino's Avatar
I have ordered my OP2 cable and have a spare ACD ECU, just want to confirm the 12V power supply I have here is OK, spec says Output 13.8V DC, 5-7amp ?
Old Dec 30, 2010 | 09:30 AM
  #389
burgers22's Avatar
Reflashed my AYC/ACD ECU today. Made the gear up from a cigarette lighter adapter for the 12V, an OBD II female connector from eBay and the trickiest bit, the AYC/ADC ECU plugs from a spare loom ( thanks Ant!).
I had to cut out a redundant pin on the ECU plug and move it, for the reflash voltage. Buzz out the correct wires on the OBD cable, then crimp them up. All pretty simple really. I now have the Ralliart maps on gravel, the standard tarmac ones on snow, and a little something I knocked up myself on tarmac.
A quick drive shows the Ralliart maps reduce under-steer, and I'm convinced add weight to the steering, which is really nice.
All in all the cable is quite easy to make up and flashes reliably. Very cool, thanks for all the work gents.
Acumus, can you give a very simple guide to loading this up in IDA?
Attached Thumbnails Break-thru: Reading ACD ECU with EcuFlash-ayc-cable.jpg
Old Dec 30, 2010 | 02:38 PM
  #390
andrewzaragoza's Avatar
this is really nice. if you don't mind maybe you can create a how to on this.
