CEL = Shift light?
Old May 6, 2010 | 09:52 PM
rodent's Avatar
CEL = Shift light?
Can you program the CEL to be used a shift light? I was going to do a quick write up on a simple $3 super bright LED homemade shift light. I'm able to do this with AEM but wasn't sure about ECUFlash. Tried to search but came up empty.
Old May 6, 2010 | 09:55 PM
LGshow19's Avatar
When i use NLS i get might knock CEL if that counts...
Old May 6, 2010 | 10:01 PM
rodent's Avatar
Well, I guess thats another use for the bright LED so any knock doesn't go unnoticed. It was pretty easy to just tap off of ECU pin 36 for the CEL. Its a negative trigger so you just need to wire up the LED/resistor to 12v constant on the other side.
Old May 6, 2010 | 10:21 PM
LGshow19's Avatar
so u would have to tap into the ECU itself?
Old May 6, 2010 | 10:29 PM
fugiwara's Avatar
What a brilliant idea!
Rodent, what do you mean you can do it with AEM? do you have AEM ecu?
Old May 7, 2010 | 05:46 AM
stryfetew's Avatar
AEM can use the CEL as a shift light. My buddies car does this.
Old May 7, 2010 | 08:02 AM
rodent's Avatar
Yes, just the wire going to the ECU. I'll have some instructions soon with the ECU pin layout, parts list, and pics. Its really easy. Turned out better than I thought for 3 bucks worth of radio shack parts.
Yes, I have AEM ECU but I was wanting to do a quick write up to help both AEM and ECUFlash owners. So basically this LED will serve as a shift light for AEM and a knock light for ECUFlash. The super bright LED gets your attention during the day especially at night! One of the best mods I've done.
Old May 9, 2010 | 07:56 PM
iTune's Avatar
Originally Posted by 0xdead
the problem is the shift light is allready used for 9 other things and it is allready getting confusing as to why it is on. Things it is used for but not limited to:
-you are pregnant
-you got somebody pregnant
-you might have hemorrhoids
-you haven't been drinking enough water
-danger to intake
-you are a danger to other people
-check your hair
-cop ahead
-turn ahead
bwahahaha!!
KatoWA
Mitsubishi TC-SST Discussion
10
Feb 24, 2014 01:15 AM
XxLaNcErGTSxX
10
Aug 10, 2009 02:57 AM
DimitrisIX
AEM EMS
Dec 26, 2008 01:54 PM
nick_622
Jun 4, 2008 07:17 PM
