Virtual Dyno - Standalone Software
Old Sep 14, 2010 | 08:59 AM
  #526
Kakihara's Avatar
Originally Posted by bbarnhill
If this is with EvoScan are you driving all over town logging to one log file? Thats a LOOOOONG log file for it to log.
Maybe something was wrong with my log we will never know because I deleted the 3000 useless lines and saved the .csv with only the 100tps measures sorry
On my first few logs I checked every box that seeemed to read something and when doing my run in 4th gear I ended up with :
around 2-3 measures per second = 35 lines at 100% tps between 1656-7781rpm
I had a good 10minutes of log like that and virtual dyno auto-trimmed the cruising without problems.
so I tried deselecting everything else thand TPS-speed-rpms and had :
around 43 measures per second = 506 lines at 100% tps between 1906-7500rpm
With this log the auto-trim wasn't working.
Evoscan seems to be over-logging when you have almost nothing checked because I have 2-6x the same rpm values, on those 506 lines maybe 200 are useful.
edit : thanks for the reply Brad, no need to waste your time on this, I'm sure you have more important things to do and I don't have the "bugged" log anymore
Old Sep 14, 2010 | 11:15 AM
  #527
Mellon Racing's Avatar
anyone having a perceived problem with vd should zip their log file up and attach it to their post along with the pertinent details about their car
year
model
transmission
gear
weight with passengers/items
Old Sep 14, 2010 | 11:22 AM
  #528
bbarnhill's Avatar
Thats a great idea!!! Welcome back to this thread Mellon!!!!
Old Sep 14, 2010 | 11:24 AM
  #529
I never left buddy, just lurking
Old Sep 14, 2010 | 01:21 PM
  #530
VGergo's Avatar
What coud be the problem ?!
here is my log
The problem :
and my settings :
Woud someone please check it ? I tried everything but not working..
Old Sep 14, 2010 | 01:31 PM
  #531
Boosted Tuning's Avatar
here is my log
The problem :
and my settings :
I think deleting all the unneeded custom column names in the options menu will fix your problem. but thats just a guess.
Old Sep 14, 2010 | 02:03 PM
  #532
VGergo's Avatar
no succes someone coud post a working ?
Old Sep 14, 2010 | 02:45 PM
  #533
I see some TPS values over 100 which are invalid, it could be picking those up
example from your log:
Code:
TPS
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
23,921,568,627,451
247,058,823,529,412
Old Sep 14, 2010 | 03:38 PM
  #534
VGergo's Avatar
Code:
TPS
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
231,372,549,019,608
23,921,568,627,451
247,058,823,529,412
in open office i didnt see TPS value over 100 :O
Old Sep 14, 2010 | 05:57 PM
  #535
bbarnhill's Avatar
If you open this file up in notepad you will see the problem. The values it records uses commas for decimal points. Its causing havoc in my CSV (comma seperated values) file reader.
Id bet these are the issues. Commas are used to seperate the columns in each row, and when data has commas in them it throws this all off.
Mellon:
I saw that too, I know one thing for sure, its not TPS. That would also cause havoc with my program if you have TPS trimming on and you are logging garbage in the TPS column.
Old Sep 14, 2010 | 07:37 PM
  #536
IrightI's Avatar
Let me know if you modified the correction factor to get it to match your mustang dyno run and if so what did you modify it to. Im trying to verify how accurate the mustang correction factor is.
Thanks,
Brad Barnhill
Virtual Dyno Developer
I just set the appropriate tire height and set the smoothing to 1 and it seemed to be within 10hp/tq.
I did notice that the first calculation seemed to differ about 30hp from what I expect. But if I set the smoothing it straightens out.
For instance if I load the log and set the tire height it will show 340hp at 1 smoothing. if I set the smoothing to 2 it will go to 29Xhp, I set it back to 1 and it's at about 310 which is pretty close to the MD.
Good luck keep up the hard work. What language was this written in? I'm a programmer, just curious .
Old Sep 14, 2010 | 08:37 PM
  #537
bbarnhill's Avatar
The smoothing makes a difference in that it gets rid of the humps in the graph. If you were to see 0 smoothing you would be thankful for smoothing its VERY bumpy to say the least.
Its written in C#. Its a straight .NET app (.NET 3.5).
Old Sep 14, 2010 | 09:27 PM
  #538
IrightI's Avatar
Yeah 0 smoothing reminds me of shark teeh
ahhh good ol C# I started studying C# to build a game. I caught on pretty quick because it's similar to Java. But I lost interest.
Old Sep 15, 2010 | 04:23 AM
  #539
bbarnhill's Avatar
Ive been writing in C# since the language/framework was in beta
Old Sep 15, 2010 | 07:13 AM
  #540
IrightI's Avatar
Very impressive sir. I'm still an amateur when it comes to compiled languages. I do mainly web based work / server administration. So everything past that is a hobby.
