Virtual Dyno - Standalone Software
Old Sep 15, 2010 | 05:25 PM
  #556
tephra's Avatar
check your region settings in windows
Old Sep 15, 2010 | 06:40 PM
  #557
VGergo's Avatar
unbelievable, it is working I have to set my region settings to Englis US :$ All of my logs get dyno graph ! Thank you for everybody
With smoothing factor 12 I got similiar values as in the VDR, maybe little more
Great, it was a tricky problem !
Old Sep 15, 2010 | 06:50 PM
  #558
tephra's Avatar
you can change it back, then change the decimal point delimiter to "." instead of ","
Old Sep 15, 2010 | 07:13 PM
  #559
bbarnhill's Avatar
ugh ... I have just recoded part of the program and it should now handle this after 1.0.7 is released.
I have redone the CSV reading portion of the program to use regular expressions and this simplifies all the reading down and Ive just stripped out another 50 lines of code in another spot. I love cleaning stuff up and watching it shrink but get more functionality at the same time.
Now back to the other issues ...
Old Sep 15, 2010 | 07:35 PM
  #560
IrightI's Avatar
Nice! Glad you guys got it worked out! Regex is no fun !! How were you doing the csv reading before? string search for commas?
Old Sep 15, 2010 | 08:31 PM
  #561
JDavenport's Avatar
Nice program
Well, I just bolted a few more parts on my IX, including some new injectors and Walbro 255. Got em scaled with the help of the mega-merge injector thread and went out to take a pull. I was running out of injector after the new intercooler and RTP install, looks like plenty of fuel now:
Even though the car is a IX, I am selecting the 8 GSR since I have the Evo 8 3rd and 4th gears in my built transmission. Weight is the same for 8/9 GSR. I entered the tire diameter straight from Toyo's site for my tires.
I've still got cams, a ported ex mani and o2 housing to install, and I need to lean out that top end a bit. This thing may hit 400awhp on the stock turbo.
Old Sep 15, 2010 | 09:21 PM
  #562
bbarnhill's Avatar
IrightI: yep just splitting it on the commas ... which now its a lot better using the regular expression BUT ... it broke some things but Im going back and fixing all of those small things. Then Im also moving the drop down that has cars in it to a drop down tree ... so that has broke some things too. But you cant make it better if you dont break it a little.
JDavenport: congrats on the installs, and hope you find this thing useful. Looks like you are.
Old Sep 16, 2010 | 02:42 PM
  #563
Mellon Racing's Avatar
congrats Jim, she's running well
Old Sep 17, 2010 | 02:29 AM
  #564
russianvr4's Avatar
hey guys, got a chance to play around with a long term project i had at the shop. single turbo 3000gt. just a baseline pull, only about an hr worth of tinkering with the tune
great program!
Old Sep 17, 2010 | 05:36 AM
  #565
AlwaysinBoost's Avatar
I must be the only one who can't get the program to work properly. Forgive me if this has beed addressed earlier and I missed it, but I did read most of this thread and tried the solutions other have provieded with no success.
I load up my evoscan logs and what I see come out isn't a clean plot, but rather a continuious line moving back and forth. I've tried trimming the RPM (3k-7k) and TPS (set to 99 and the "auto trim tps" box is checked) but still wind up with the same maze of a plot. I tired different logs, but this is how all my logs are plotted. I also tried hiding row/columns in the log but that had no effect either.
What am I doing wrong? is it because there is too much info in the logs? some are 15-20 minute logs with lots of street driving and a dozen or so WOT pulls mixed in there. None of them are just WOT pulls, where I start the log, do a pull and stop, maybe thats what my problem is...???
Old Sep 17, 2010 | 06:03 AM
  #566
Raptord's Avatar
yes that's your problem. You need a log with only ONE pull in it.
Old Sep 17, 2010 | 01:06 PM
  #567
Boosted Tuning's Avatar
^ This. You need to have one WOT pull per log.
Old Sep 17, 2010 | 01:34 PM
  #568
bbarnhill's Avatar
Ohh lord ... 20 minute logs ... holy crap!!! its hard to cram 20 minutes of data in a small window and expect a pretty graph
Try doing a 15-20 second log of a WOT pull and then stop the run. Raptord and Boosted_Tuning are correct.
Old Sep 17, 2010 | 01:39 PM
  #569
Raptord's Avatar
Usually I start logging when I leave the house and stop when I arrive to my destination, so I regularly have 20+ minute logs, but when I want to graph a pull, I copy the data from the pull in a new csv and save that. That way I have just the pull if I want to look at that, and the cruising log if I ever need it.
Old Sep 17, 2010 | 01:45 PM
  #570
I tired copying a pull to a new .csc (file save as), but it wouldn't read the log... now that I think about it, there might have been more than 1 pull on that log.
