Virtual Dyno - Standalone Software
Old Aug 10, 2010 | 01:14 AM
  #406
merlin.oz's Avatar
If you install, without first deleting the old xml files, it does not install the new xml files.
And throws an error.
Delete the old columns xml, re-install, and it works.
Old Aug 10, 2010 | 01:32 AM
  #407
merlin.oz's Avatar
An error with rpm found.
My log starts at 2624rpm, stops at 6751rpm.
But, the graph shows it starting at about 1200rpm and finishing at about 8000rpm.
Old Aug 10, 2010 | 06:52 AM
  #408
bevolucion's Avatar
well this is what I see when I run the program with one of my logs, I dont know why is very jumpy when smoothing is at 0, it does get better with around 2 in the smoothing table, but the hp is a lot lower. My ? what HP do I actually have? Sorry about the probably stupid question, but I am not familiar with dynos at all, I have never brought my car to a dyno. The horse power it shows is 537hp at 6100 rpms at 0 smoothing. I am pretty confident that my car is built to support this, but I am not sure if this number is accurate, because the graph is not smooth. May be the problem that I am using mitsulogger?
Old Aug 10, 2010 | 07:02 AM
  #409
Mellon Racing's Avatar
you'll likely need to run at least 5 smoothing...keep bumping it up until the curve is smooth.
Old Aug 10, 2010 | 07:12 AM
  #410
bevolucion's Avatar
I do but then it says I have about a 100 less hp, my ? do I read the hp after the smoothing, or my actual hp is at 0 smoothing and smoothing option is just for better graph line?
Thanks for the reply mellon.
Old Aug 10, 2010 | 07:15 AM
  #411
l2r99gst's Avatar
After the smoothing. Use just enough smoothing to get a relatively nice curve.
Old Aug 10, 2010 | 07:18 AM
  #412
^^ correct, with the smoothing too low the graph is filled with spikes and not representative of your true hp/tq. Keep adding smoothing until it's smooth. Most people need 5-10 smoothing, some need much more if they have a jumpy rpm signal.
Old Aug 10, 2010 | 07:19 AM
  #413
bevolucion's Avatar
thanks guys, what am gona do today is log a few runs and try it out a few time and see if the numbers are consistent.
Old Aug 10, 2010 | 07:23 AM
  #414
l2r99gst's Avatar
The amount of smoothing is dependent on your logging speed and resolution of data. People who use 2-byte RPM will need different smoothing than 1-byte and people who use DMA will need different smoothing than MUT/Evoscan, etc.
Since this calculates your tq/hp from the data, you adjust your smoothing to fit your data and data rate. It's pretty obvious when your smoothing is correct. But, don't use too much...just enough to get a decent curve.
Old Aug 10, 2010 | 09:22 AM
  #415
bbarnhill's Avatar
got a log for me to look at so I can fix it?
Old Aug 10, 2010 | 01:21 PM
  #416
nonschlont's Avatar
Delete the old xml and reinstall and it works.
+1
The last 2 versions, I could just install the latest version... The last version(1.5) required that I uninstall, and reinstall to find the .xml files/columns
Old Aug 10, 2010 | 02:30 PM
  #417
bbarnhill's Avatar
I didnt distribute the graphsettings.xml with this edition to keep from having to overwrite your current settings but I see that is not a good idea. Ill be posting a new copy of V5 in a second. Im sorry for this mishap. I realize now that I modified the settings file structure and it requires that I disribute it. It was a mistake on my part when packaging up the files.
So if you want to just uninstall the current v5 and download the copy that is posted to the website now. It should install to the default location nonschlont. I wanted to save everyones settings but now I realize that with such few settings it isnt that big of a deal to redo the settings when you get a new version. It will keep more consistancy to the distributions.
Old Aug 10, 2010 | 02:35 PM
  #418
itzwolf's Avatar
Brad,
Boost doesn't seem to get plotted out on AEM logs...
Old Aug 10, 2010 | 03:14 PM
  #419
bbarnhill's Avatar
what is the column name itzwolf? Send it to me via email. bradbarnhill at hotmail
Old Aug 10, 2010 | 04:51 PM
  #420
nonschlont's Avatar
its no biggie, just wanted others to know how to bypass it/confirm merlins findings. Glad u could figure it out, quickly for all of the others. I'll install the latest version just for S & G's...
Its coming along nicely, keep up the great work!!!
