Virtual Dyno - Standalone Software
Old Jul 7, 2010 | 07:36 PM
  #256
bbarnhill's Avatar
I guess you can see from the previous post that 1.0.0.4 is getting close to being released. I have a few things to clean up but its close. Its getting MUCH better. I reworked the graph a bit and added a quick action bar to the graph to keep you from having to go to the menu so much ... anyway I wont give away all the details of the new version coming or it would spoil the suprise.
Old Jul 7, 2010 | 07:53 PM
  #257
itzwolf's Avatar
Well hurry up.... j/k
Looking forward to the release, everything sounds good and the pictures look good!
Old Jul 7, 2010 | 09:07 PM
  #258
bbarnhill's Avatar
Im hurrying ... dang itzwolf put a fella under some stress
Ive just got some cosmetic stuff to do while I wait on the beta tester (aka. Mello-Mellon) to give me his seal of approval.
Old Jul 7, 2010 | 09:49 PM
  #259
stryfetew's Avatar
Is the software set to auto-update? Or do you need to download and run the installer? Another question the default settings in the program what would it equal to dyno wise, dyno jet, mustang etc?
Old Jul 7, 2010 | 10:32 PM
  #260
bbarnhill's Avatar
Technically all dynos are different and have different correction factors set on them. Ive found that the 1.09 correction factor is very close to most DynoJets barring they have their correction factor set to something weird. I did have one log that was in a previous post that had a Dynojet set to 1.03 and I had to back my correction factor down when comparing it due to my numbers being higher than what their dyno was showing.
Using the default I have compared it to VDR and DLL and its pretty close with the default settings to both of them set for Dynojets.
There is a new version coming out with the default of 1.09 which is lower than version 1.0.0.3 (default in it was 1.12).
Old Jul 9, 2010 | 06:38 AM
  #261
bbarnhill's Avatar
Bear with me as I am taking a little longer to release 1.0.0.4 but I want to add a few more things before releasing it. Hope you guys dont mind a little more fine tuning and features. I think they are worth the wait.
Old Jul 9, 2010 | 08:30 AM
  #262
Mellon Racing's Avatar
being that the current version is usable, I'm okay with waiting a little longer for the next one if it means more features and polish
Old Jul 9, 2010 | 12:05 PM
  #263
bbarnhill's Avatar
Ohh it's polished like a chrome turd!!!
Gonna work on it some more tonight I hope. Gonna knock out that tire size calc tonight. I keep making these hollow promises but dang the wife is needy.
Old Jul 11, 2010 | 09:52 AM
  #264
itzwolf's Avatar
Any updates?
Old Jul 11, 2010 | 02:42 PM
  #265
bbarnhill's Avatar
Yeah made a few changes today so far ... working with Boosted_Tuning and Mellon Tuning on testing this thing. These guys are helping me out a bunch. Ive got the following changes made so far:
- Fixed a bug where logs could have blank data in some cells and data in others of the same column
- Added AEM log support (must be exported in TEXT format)
- Access Port (AP) logs now supported
- AFRMAP removed from the AFR column list due to it not being an actual measure of AFR
- Fixed bug where if AFR has empty cells it would crash
- Fixed bug that would graph cells that should have been trimmed by the TPS trimming, this caused graph anomalies
- Changed loading time of logs to only when first loaded, which prevents loading all logs everytime the graph is redrawn
- Changed colors to be Red/Blue for first run loaded to conform with most dyno graphs
- Trim out data samples that have the same RPM as the previous row, which causes anomalies and high HP numbers
- Trimming of RPM now is live and doesnt cause graph to blink
- Graph quick action bar added to top right corner of graph (wont show up on print outs, or screenshots)
- Save graph image added to quick action bar
- Copy graph to clipboard added to quick action bar
- Print graph button added to quick action bar
- Toggle data points added to quick action bar
- Color changes for uniformity
- Default CF set to 1.09
- Store default image for the graph background
- Limited loaded runs to a max of 3
- Default tire sizes for all vehicles were set to the stock tire size
- Legend wording reworked to show weight and remove one unneeded entry.
Thats why it is taking so long ... its a big update. The graphing looks TOTALLY different now, and I think you will be pleasantly suprised.
Old Jul 11, 2010 | 05:17 PM
  #266
Boosted Tuning's Avatar
... working with Boosted_Tuning ......
Why did I get an underscore? Its "Boosted Tuning"... BRAD.
Lol, just playing
Old Jul 11, 2010 | 05:18 PM
  #267
You forgot the built in tire calc....
Old Jul 11, 2010 | 06:49 PM
  #268
bbarnhill's Avatar
Ohh ... umm ... yeah thats in there too.
Got a bug with one more thing and we should be ready for a release.
Old Jul 12, 2010 | 02:04 PM
  #269
fostytou's Avatar
EvoM Community Team
This is looking awesome!
The only bug I could easily pick out is that the graph was scrollable... IE: When I scrolled with my mouse wheel the graph scrolled and re-scaled, which also re-scaled the calculated max hp and torque.... so it quickly looked like I had 1400HP.
Also, if it was smart enough to remember the last car used as a default and or just after you drag a graph in and select one car that would be very helpful. Even better if you could set defaults for a vehicle including wheel size / weight / etc.
Thanks so much for your work on this!
Old Jul 12, 2010 | 07:25 PM
  #270
daymean's Avatar
Quick question bbarnhill -
Why is the final drive for the 9mr in your program - 4.529 and in JOT's VDR the final drive for the 9mr is 4.583?
