Virtual Dyno - Standalone Software
Old Jul 21, 2010 | 12:03 PM
  #316
Spec-Ops1's Avatar
I plan on it... in the office now.
What it should look like if you are trying to keep it the same as standard dynos is...
Run 1 - solid lines, TQ/HP Red and Blue
Run 2 - dashed lines, TQ/HP Red and Blue
Run 3 - Could go Solid again with different colors
Run 4 - Dashed, same colors
It is really up to you, just typically, the runs share the same line type, just the color changes from HP to TQ
Old Jul 21, 2010 | 01:04 PM
  #317
bbarnhill's Avatar
Can you send me a graph with four runs graphed so i can see what it looks like? We will work on the look but ill have to make an executive decision cause some ppl are screaming different things. I hate those decisions . Just let me look at it first, i dont rule anything out before giving it a shot ... Even with hookers
Old Jul 21, 2010 | 01:14 PM
  #318
Spec-Ops1's Avatar
Here is a link to 2 runs over each other... Boost is in green, so ignore that. Solid lines are 1 run, Dotted the 2nd.
Old Jul 21, 2010 | 01:25 PM
  #319
Boosted Tuning's Avatar
I personally like the way it is setup in 1.0.5.
Old Jul 21, 2010 | 01:26 PM
  #320
Spec-Ops1's Avatar
i haven't played with that version yet. Just saw there was an update this morning. It would just be easier if we were tracking the same type of line for a run instead of 2 different colors (Red and Blue) and 2 different line types per run.
Old Jul 21, 2010 | 01:45 PM
  #321
In 1.0.5 its like this.
Run 1 is one color (ie RED). HP is solid, TQ is dotted.
Run 2 is one color (ie Blue). HP is solid, TQ is dotted.
Etc, etc
I like it this way.
And like you, I also complained about how it was in previous versions. When you see 1.0.5, I think you'll like it too.
Old Jul 21, 2010 | 01:46 PM
  #322
Spec-Ops1's Avatar
Hopefully, or i'll have to retrain my eyes. Whatever is easier... i just am so use to seeing dyno graphs and they are all the way that I suggested by default.
Old Jul 21, 2010 | 02:05 PM
  #323
bbarnhill's Avatar
I think since they are the same color it helps out a lot. I agree the older one was harder to follow.
Old Jul 22, 2010 | 10:28 AM
  #324
SiliconTek's Avatar
Is there anything special that has to be done to display AccessPort logs? I load my logs and it says 0HP/0TQ.
Old Jul 22, 2010 | 12:27 PM
  #325
bbarnhill's Avatar
Check your tps trim value
If you still have problems send the log to bradbarnhill at hotmail and ill take a look
Old Jul 22, 2010 | 01:04 PM
  #326
SiliconTek's Avatar
[quote=bbarnhill;8516053]Check your tps trim value
NVM I found it thanks!
Old Jul 22, 2010 | 06:24 PM
  #327
TouringBubble's Avatar
I decided to give this a try tonight ... I have a question.
Does the application pull in the baro and temp data from logs automatically for SAE correction? I don't have any logs with that data currently.
Old Jul 22, 2010 | 07:43 PM
  #328
bbarnhill's Avatar
silicontek: Let me know if there is anything else to do for ya. There is an update in 1.0.5 that fixes some issues with TPS trimming, just wait on that update within the next week.
TouringBubble: The baro and temp data is put in manually, as its not stored in any log that Ive seen.
Old Jul 22, 2010 | 08:47 PM
  #329
stackhouse's Avatar
Brad, the application looks like its coming along nicely. I havent had a chance to play around with it as much as I'd like, but from what I've seen so far, its pretty damn cool. Much better than any other freebie that Ive seen. PMing you with some more info.
Old Jul 22, 2010 | 09:11 PM
  #330
The baro you log would work but not the temp, as the temp we log is AIT, and not the ambient temp.
