Virtual Dyno - Standalone Software
Old Jan 21, 2012 | 04:23 AM
  #1306
NINJA63's Avatar
hello brad,
since the update i have a error message when opening virtual dyno 1.1.7
could not load columnsnames.xml
and after i enter the log,i have:
E106: data at the root level is invalid.line 353,position 11
i haven't change anything since the update!!!
can you point me what must i do,please??
thanks
greg
Old Jan 21, 2012 | 05:15 AM
  #1307
tscompusa's Avatar
I got that error also.. i uninstalled it, removed the program files folder, and reinstalled it, and its fine now..
my only complaint is now it reads 4hp less as opposed to 1.1.6 lol.
Old Jan 21, 2012 | 05:42 AM
  #1308
NINJA63's Avatar
heyyy,thanks!!
i've do that,and work perfect now!!
thanks again!!
Old Jan 21, 2012 | 05:57 AM
  #1309
tscompusa's Avatar
no problem. now donate some of your $ to Brad for making such a badass program for FREE!
Old Jan 22, 2012 | 03:57 AM
  #1310
NINJA63's Avatar
i have already given there 6 month!!
and yes,it's a badass program!!
Old Jan 22, 2012 | 06:51 PM
  #1311
bbarnhill's Avatar
@tscompusa: I looked a back (as I keep a record) ... you were my first donation brother. Thanks for the belief in me from the beginning. Its come a long way from where it was for sure. Ive put in hundreds of hours since then. Ohh and the power difference comes only from the change I made to smoothing in 1.1.6/1.1.7 as there was a bug in the smoothing algorithm that I made. It actually smoothed the first part of the run more than the last part of the run if I remember correctly. It was an obvious flaw when I stumbled upon it while looking for another bug. I fixed it and NOW it is correct according to my tests. Sorry it dropped the power by a smidge but I felt like accuracy was WAY more important than egos Keep the faith my friend and thanks again.
@Ninja63: Sorry about that error man. I reworked the file structure of the project and organized some of the code in seperate DLL files. It may have caused an error or two by doing that. I feel like it is worth the trouble to uninstall and reinstall for me to be able to reorganize the code and clean in up some.
Old Jan 22, 2012 | 08:34 PM
  #1312
90blackawdtsi's Avatar
I cannot figure out how to get this to work correctly.
I am trying this from logs that I have taken from my 90 Talon.
I am guessing that the speed sensor signal being erratic it is throwing the software off.
The dash speedo is smooth but in the logs its pretty jagged.
If I need to post up a log let me know.
Old Jan 23, 2012 | 10:56 AM
  #1313
NINJA63's Avatar
brad,don't feel sorry about that!!
you're making a great job,and really appreciate it!!
my motec log work like a charm since your update,you're the man!!
Old Jan 23, 2012 | 11:58 AM
  #1314
Boosted Tuning's Avatar
Speed data is not need. Just time, RPM and TPS.
Old Jan 23, 2012 | 12:09 PM
  #1315
bboyalan's Avatar
Originally Posted by NINJA63
heyyy,thanks!!
thanks again!!
+1 thanks for that as well. I also saved a copy of my "Profiles" to substitute with the fresh install.
Old Jan 23, 2012 | 05:27 PM
  #1316
Creamo3's Avatar
Great work as always, I'm liking the new functionality
Old Jan 23, 2012 | 05:50 PM
  #1317
tried with just RPM and TPS and the standard time format Link uses and it still shows low, like only showing 57hp, LOL
Old Jan 24, 2012 | 04:38 AM
  #1318
bbarnhill's Avatar
what data logger are you using? I may need to have a look at the log as it may be a new log format with a changed time format.
Old Jan 24, 2012 | 06:15 AM
  #1319
I am using Link V3. I believe it to be "timestamp" related. I will shoot you a log over this afternoon and let you decifer it.
Old Jan 24, 2012 | 08:15 AM
  #1320
bbarnhill's Avatar
Link V3? I dont believe I support that logger yet. Maybe its time to support it.
