Virtual Dyno - Standalone Software
Old Oct 31, 2011 | 03:03 PM
  #1246
wizzo 8's Avatar
Yea never thought of that. I guess its not that important. The only road in my area thats safe to make a pull isnt 100% flat so I make a pass in both directions and one way always shows higher numbers. I just average them which is fine by me.
Old Oct 31, 2011 | 09:19 PM
  #1247
Steveevo9's Avatar
Originally Posted by bbarnhill
post an example log
Hey Brad,
This only happened with v1.14, prior to that v1.12 was great on both computers. Here's a log to try (this log and my others all worked great). I'm unable to view the log once it's been uploaded.......? Is it because it's a csv file, it doesn't appear on the type of files under 'attachment key'?
Old Nov 1, 2011 | 03:01 AM
  #1248
bbarnhill's Avatar
huh? You should be able to attach a file to your post.
Old Nov 2, 2011 | 12:10 AM
  #1249
Steveevo9's Avatar
Trying again now....just came up with EvoScanDataLog_2009.04.01_12.38.39.csv:
Invalid File
. I can email it to you if you want Brad, let know mate.
Old Nov 2, 2011 | 05:47 AM
  #1250
Raptord's Avatar
You need to put it in a .zip archive first.
Old Nov 2, 2011 | 09:11 AM
  #1251
bbarnhill's Avatar
You can either zip it up and put it on here or email it to me. Either one is fine with me
Raptord: thanks for the help buddy.
Old Nov 2, 2011 | 02:24 PM
  #1252
VGergo's Avatar
Do you plan to support Motec Ecu formats ?
Old Nov 2, 2011 | 02:49 PM
  #1253
killerpenguin21's Avatar
brad,
if i can provide you with info on a set of cars could you add them in (what the list of specs you need?)? tuning/logging is done through log works which i believe VD already supports right?
Old Nov 2, 2011 | 05:19 PM
  #1254
bbarnhill's Avatar
VGergo: Yes I do. Id like to collect a few MoTec logs before supporting it though. I have one log and Id like to get a couple to add support. I want to know that the one I have is UN-edited.
killerpenguin21: sure can. Ill send you a PM with the format to send me the data in. They need to be unmodded car specs though. I like to add stock vehicle specs to the database.
Old Nov 2, 2011 | 10:51 PM
  #1255
Steveevo9's Avatar
Thanks for that Raptord, it did cross my mind so I'll try that or email it to Brad.
Old Nov 3, 2011 | 03:04 AM
  #1256
bbarnhill's Avatar
Ill take a look at those logs later. Ive got two 12 hour shifts at the hospital lined up for Thurs and Fri. Ill get at them asap. Please be patient.
Thanks,
Old Nov 3, 2011 | 09:49 AM
  #1257
bnr34rb26dett's Avatar
im new in this tuning world of evos. i just recently got into it with my tactrix cable and using openecu.
now from what i understand, in order to use this program,
1. i need to purchase evoscan?
2. what kind of pulls do i have to record for accurate dyno plot? i hear 3rd and 4th......
sorry this is a noob question but i did not find a solid instruction anywhere on this....
Old Nov 3, 2011 | 01:50 PM
  #1258
Raptord's Avatar
1. Yep.
2. You'll want 3rd gear pulls from about 2.5k rpm to 7k.
Make sure you untick "log to screen" in the logging menu and only log the items you need (mainly rpm, tps, timing, knocksum, load)
Old Nov 4, 2011 | 06:07 AM
  #1259
1. Yep.
ok.
im going to start my Vdyno experience by buying the program first
more questions later
thanks
lol
Old Nov 4, 2011 | 07:15 AM
  #1260
wizzo 8's Avatar
ok.
thanks
lol
Once you get your Vdyno experience and are happy with it be sure to donate to Brad. Its a great program and easy to use.
