Virtual Dyno - Standalone Software
sigh ... the profiles xml format has changed so I pushed your old profiles (that wont work) to a seperate file (profiles.xml.old) in the installation directory. This was because I wasnt going to be mean and just delete your profiles. Tuners would start showing up at my door. I have tested the profile editor over and over and it isnt giving me any problems. If you can recreate a problem PLEASE send me a message detailing how. I am committed to fixing these problems but I need to know how to replicate them so I can.
Thanks,
Thanks,
Method 1
- Start with clean Virtual Dyno, no profiles.
- Add a new profile, Mitsubishi/Ralliart/Ralliart 2010-2010 Sportback [Auto], Gear 3, Year 2009, Save.
- Load a log.
- Select the profile.
System.Exception: E208: Object reference not set to an instance of an object.
at RunControl.cRunControl.Error(String ErrorNumber, Exception ex)
at RunControl.cRunControl.PopulateGearDropdown(CarPar ametersRow row)
at RunControl.cRunControl.SetFromProfile(CarProfileRo w ap)
at VirtualDyno.frmVirtualDyno.ProfilesMenuProfile_Cli ck(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Method 2
- Select the profile (doing this first, this time).
- Load a Log (and this one second)
Pop-up window saying, "E106: E208: Object reference not set to an instance of an object."
Best of luck! Damn software - always messing the humans around...!
Rich
OK OK OK ... Im getting a ton of logs as error reports and I look in there and the only thing wrong is that people aren't logging TPS. If you don't log TPS it will throw an error (E101). You have been warned
yes the server is offline ... Im headed out there in a bit to fire it back up. I hope nothing is wrong with it. I noticed this a bit ago. Sorry for the trouble. I plan on getting some webspace soon and rehosting it at a datacenter. Just been busy with state board exams and such
Should be back up tonight sometime.
Brad mentioned problems earlier today so he might not have it repaired yet. You can download a copy from our Tuning section near the bottom http://www.mellonracing.com/index.ph...dex&cPath=1_28
Hey man no problem. It was unexpected that the power would stay out here so long. I dont know what happened as I was 30 miles away for the last couple of days. I am cleaning out the freezer now as it looks like half of it thawed and refroze. I havent had any power outages longer than a blink in 5 years. This better not become a habit.
I'm having trouble getting the new version to work (v.1.1.1). It will work when it opens automatically after I download it, but once I close it out and try to open it back up I get the E115 error message along with several other messages. I've tried uninstalling and reinstalling everything several times now and I keep getting the E115 error. I even tried doing a system restore so that I could go back to using V1.0.8 and that won't even work now. Can anyone help me out?
Ian0611: This is an issue with Windows 7/Vista that Im going to correct in the next release. It has to do with permissions not being given to the program files folder. Im going to store the car defs and all other files that need written to from time to time in a different folder. I worked on it some last night but I was tired after 14 hours at work tuesday and not sleeping well and taking my state boards yesterday. Ill get on this again today as soon as I mow the yard. This will hopefully solve a lot of issues people have been having.
Thanks for reporting the error and I appologize to everyone for it. Its a bad programming practice to do what I did and I just found out after reading for a few articles. Shame on me
