Virtual Dyno - Standalone Software
Old Oct 5, 2011 | 08:08 AM
  #1201
Mellon Racing's Avatar
I think the problem is that you're opening a compressed zip file that has logs inside and trying to drag and drop directly from there. Try extracting the log files from the compressed zip file and then dragging and dropping.
Old Oct 5, 2011 | 09:53 AM
  #1202
babaz7's Avatar
i tried to extract the log files but it says cannot open C:\program files (x86)\evoscan\evoscan v2.6\saveddatalogs\oct 5 2011 1.5 bar stock runs\evoscandatalog_2011.10.05_04.28.18.csv
the system cannot find the path specified
Old Oct 5, 2011 | 10:04 AM
  #1203
ok, I'm not sure what's up with that error (windows problem most likely) but going forward when you do a log file, don't zip them up and it will be a non issue. Try making a new log file with evoscan and drag and drop it into virtual dyno.
Old Oct 6, 2011 | 07:32 AM
  #1204
Kakihara's Avatar
Juts to make it clear for some people that believe virtual dyno is showing BHP or some kind of European power at the engine :
bbarnhill could you please confirm and write in all letters that your virtual dyno graph shows whp and not power@flywheel ?
Thank you in advance I would really appreciate the effort.
Old Oct 6, 2011 | 08:37 PM
  #1205
bbarnhill's Avatar
Virtual Dyno shows WHP (Wheel Horsepower ...aka the HP that matters).
Ohh and Mellon is absolutely correct. Dont drag files from a zip folder to Virtual Dyno. Extract your files first. Mellon should know ... he uses the software more than I do
Old Oct 7, 2011 | 05:21 AM
  #1206
SPOOLEDTSiAWD's Avatar
I was having the same problem as babaz7 was having. I had to open my logs through the programs files and go to saved logs. It shows the sample logs in the file and none of my saved logs. On the top of the tool bar there is a button that says compatability files or something. Your saved logs will show up after that. Copy all of your saved logs then open virtual dyno. When you click open logs and paste your logs into the area that says sample logs.
That might be confusing so pm me if you need help
Old Oct 7, 2011 | 03:25 PM
  #1207
bbarnhill's Avatar
Im a little confused as I dont send any sample logs with virtual dyno
Old Oct 7, 2011 | 03:26 PM
  #1208
The sample logs come from EvoScan. There's only 2 in there. They should be labeled as sample 1 and sample 2
Old Oct 7, 2011 | 03:53 PM
  #1209
bbarnhill's Avatar
so are you having trouble opening the sample logs? What exactly is the problem again?
Old Oct 8, 2011 | 05:23 AM
  #1210
babaz7's Avatar
thanks alot dude! i did as you mentioned above and guess what? it WORKED!!!
cant thankyou enough man i was trying from the past two days downloaded all kinds of softwares to extract files and all but what you said was the only way it showed my graph in VD!
Old Oct 8, 2011 | 05:24 AM
  #1211
babaz7's Avatar
thanks dude for all the help, finally i managed to do it from what SPOOLEDTSiAWD
stated!
Old Oct 8, 2011 | 05:31 AM
  #1212
babaz7's Avatar
and can you tell me how accurate is VD? cause in my part of the world we dont have a dyno so can i say that the numbers my car is putting down on VD is close to real dyno numbers or not?
Old Oct 8, 2011 | 06:44 AM
  #1213
bbarnhill's Avatar
Its been tested on many cars and dynos by multiple people. Ive personally tested it with a 700hp Evo and it was within 1-2 HP and 2-3 TQ of what it put down on the dynojet.
Ask Mellon Tuning, or any other tuner on this forum that uses it if its accurate
Old Oct 8, 2011 | 09:57 AM
  #1214
babaz7's Avatar
amazing , and can you tell me what is smoothing? shall i keep it on 1 or someother number?
Old Oct 8, 2011 | 10:03 AM
  #1215
smoothing is used to take make the lines smoother. Too much smoothing and it kills your hp/tq, too little and it can look pretty rough. I usually end up at 1-2 smoothing.
