Virtual Dyno - Standalone Software
Old Sep 1, 2011 | 04:48 PM
  #1171
bbarnhill's Avatar
hum ... very good point ... I may have to limit the amount of variables viewable at once but that looks like a better way to layout the graphs. Would limiting the number of variables viewable at once be a killer?
Old Sep 1, 2011 | 08:57 PM
  #1172
Boosted Tuning's Avatar
No, dont limit variable. Just dont make the Y axis "silly" like you have it now. I have told you this. Just make it like this...
Old Sep 2, 2011 | 07:54 PM
  #1173
bbarnhill's Avatar
everything would have the same scale then ... your finer things like knock wouldnt be visible if you graphed load too ... that make sense?
Old Sep 2, 2011 | 08:01 PM
  #1174
bbarnhill's Avatar
got some dedicated webspace but moving the site is being a pain. So in the next few days when they transfer my domain if I dont have everything moved there may be some server outages till I get it rebuilt. Just warning you guys of the move. Grab it now if you want it or it may be down for a few days.
Thanks ... and bear with me as I move this thing to a more reliable connection and server environment.
Old Sep 2, 2011 | 08:02 PM
  #1175
ziad's Avatar
Multipliers man
Old Sep 2, 2011 | 08:49 PM
  #1176
Its called "scaling factor". Thats how to make it work with one y axis.
Like in the pic I posted, the wideband data is scaled by a factor of 10. Otherwise it would be smooched at the bottom and you wouldnt be able to see small changes in it.
Old Sep 3, 2011 | 01:34 AM
  #1177
evoscan's Avatar
Silver Sponsor
yep, if you load the EvoScan\SavedDataSettings\*.xml file, each item has a ScalingFactor, it is editable by right clicking the data items list on the main screen. That way you can have a nice single axis, and its very easy to spot knock sum if factor of 10 is applied. i.e. 8 knock will show up as 80 on the chart. and the real values are shown in the EvoScan charts' tooltip.
Old Sep 3, 2011 | 03:32 AM
  #1178
VGergo's Avatar
If we can view once in 5-6 row data from the log what we can change it would be perfect. How the Motec logging works we can check a complete running and see how fast the turbo boost again after shifting and like this .
Old Sep 25, 2011 | 06:11 PM
  #1179
bbarnhill's Avatar
1.1.3 released. Should fix the permission issues people have been having and a few other issues. I added a few small features. Hope everyone likes it, just start up Virtual Dyno and it should update itself.
Old Sep 26, 2011 | 04:43 AM
  #1180
binky's Avatar
Sweet
-Bink
Old Sep 26, 2011 | 07:29 AM
  #1181
ferocus's Avatar
There is something wrong with 1.1.3 update
My car had 485 WHP on 1.1.2 and now 1.1.3 shows 1036WHP with the same log
I erased and recreated the profile and I got 1036 again.
Old Sep 26, 2011 | 08:58 AM
  #1182
bbarnhill's Avatar
1.1.3 did not have any modifications to the power calculation formulas.
You are welcome to send me that log in question and Ill be glad to look at it. Be sure to tell me what gear it was taken in.
Old Sep 26, 2011 | 09:13 AM
  #1183
dude's Avatar
My power and tq numbers went up from 1.1.2 as well...same logs.
Old Sep 26, 2011 | 09:41 AM
  #1184
ferocus's Avatar
In File->Options->Graph there is "Metric Wght and temp"
If it's ticked when I do "Load run" I get 1036 whp
If it's un-ticked I get 485 whp
Old Sep 26, 2011 | 10:04 AM
  #1185
bbarnhill's Avatar
Its probably because if its checked your weight is in KG instead of LBS. Thats a new feature in this edition.
