Virtual Dyno - Standalone Software
Old Sep 26, 2011 | 10:56 AM
  #1186
ferocus's Avatar
Because of the 1:2 report i think it's not my weight it's something bigger... i think it's a car weight problem
with my weight in kg i get from 1036 to 999 hp
if i change car weight in profile i get 485
Old Sep 26, 2011 | 11:16 AM
  #1187
bbarnhill's Avatar
ok im not following you. If you change the weight in the profile from what to what and what are the settings at the time you change the weight?
Im trying to replicate this problem so I can see if its an issue.
Old Sep 26, 2011 | 11:27 AM
  #1188
ferocus's Avatar
When you create a profile, after choosing the car you get the car weight in lbs (3517) even if you ticked metric weight and temp.
You have to manually change car weight from lbs (3517) value to kg value (1595) and save profile.
Old Sep 26, 2011 | 01:59 PM
  #1189
bbarnhill's Avatar
Ohhhhhhhhhhhhhhhhhhhhhhhhhhh
Very good observation. Ill work on getting this fixed asap. Dont get too frustrated till I get that fixed. That was an oversight while trying to get the metric units in there asap.
Old Sep 26, 2011 | 04:29 PM
  #1190
tscompusa's Avatar
Id just like to say you're doin a hell of a job on the program Brad! Keep up the good work.
Old Sep 26, 2011 | 05:08 PM
  #1191
merlin.oz's Avatar
+1
Old Sep 26, 2011 | 05:31 PM
  #1192
wizzo 8's Avatar
+2. About time for another donation
Old Sep 28, 2011 | 05:45 PM
  #1193
itzwolf's Avatar
Originally Posted by bbarnhill
1.1.3 released. Should fix the permission issues people have been having and a few other issues. I added a few small features. Hope everyone likes it, just start up Virtual Dyno and it should update itself.
Brad,
Noticed the new location is "C:\Users\<ProfileName>\AppData\Roaming\" but I was under the assumption it should be located under "C:\Users\<ProfileName>\AppData\Local\" ?
Doesn't really matter as its working but that's where I thought it was supposed to be located on standard applications. I know when I backup data that's where I would look not roaming...
And great work on the newest version, been playing with it tonight and looking good so far!
Old Sep 28, 2011 | 07:44 PM
  #1194
bbarnhill's Avatar
Thanks for all the +1s and +2s
Glad you guys find it useful, and Im glad the community can use some of my sloppy code
itzwolf: I put it in the roaming profile directory just in case someone used roaming profiles out there at work. I wanted to make sure I didnt have to change it later ... unless windows 8 throws a monkey wrench in there somewhere.
Old Sep 28, 2011 | 08:10 PM
  #1195
itzwolf's Avatar
10-4
Old Sep 30, 2011 | 12:16 PM
  #1196
project_skyline's Avatar
When is the graphing feature coming? I'll donate if that gets you motivated lol.
Old Oct 4, 2011 | 11:51 PM
  #1197
babaz7's Avatar
okay so i just downloaded the software but somehow it doesnt show my data logs?
when i go in to load runs it only show sample evoscan logs but not mine,why is that please help?
Old Oct 5, 2011 | 03:06 AM
  #1198
bbarnhill's Avatar
You have to browse for your files?
Your description is a little vague. Help me help you by explaining this a little more. You can always just drag your runs over to virtual dyno and drop them on the software and it loads them.
Old Oct 5, 2011 | 05:40 AM
  #1199
babaz7's Avatar
okay so the best way to explain is this video: http://www.youtube.com/watch?v=lvcvNhdGhp8
as you can see i cannot open my logs in VD only the pre installed evoscan logs can open?
Old Oct 5, 2011 | 07:08 AM
  #1200
05blue8's Avatar
Send him one of your logs...I'm sure he can figure it out
