Virtual Dyno - Standalone Software
Old May 7, 2011 | 06:44 AM
  #1021
bbarnhill's Avatar
I also need frontal area and coefficient of drag that isnt listed there. Ive been wanting to add Evo 1-4 but thats the big things missing that I need to add them.
Old May 7, 2011 | 06:52 AM
  #1022
evonut270's Avatar
ill see what i can do but it may be difficult to find.
Old May 7, 2011 | 07:03 AM
  #1023
bambooi's Avatar
Originally Posted by tscompusa
in Beissens thread u can see i used the log on the dyno and it was dead on.. almost 100% picture perfect.. it would only be fair to use the dyno log to test the accuracy of the program itself..
the road is gonna show slightly different results if the turbo spools differently due to afr changing etc.. to many variables.
Did you guys weight the car or just put a rough estimate of the weight? Do dynos have a scale on them? I have access to a certified truck scale, but I have just been leaving the default weight in(which is less than what my car really weighs). Are putting modifying the weight in the program?
Old May 7, 2011 | 07:10 AM
  #1024
wizzo 8's Avatar
I got mine weighed. I would try and keep the weight within 100lbs at most though.
Old May 7, 2011 | 12:14 PM
  #1025
MercenaryX2's Avatar
http://www.vfaq.com/mods/Trannies.html
There's all the info for the transmissions. The coefficient of drag is 0.29 for both 2g AWD and FWD. Frontal area is 20.3 (atleast that what I calculated.)
Anything else you need?
Old May 7, 2011 | 02:46 PM
  #1026
bbarnhill's Avatar
yeah the year and models that that information applies to.
Old May 8, 2011 | 11:23 AM
  #1027
1g is 89-94. 2g is 95-99.
Old May 8, 2011 | 09:39 PM
  #1028
bbarnhill's Avatar
are the weights the same for all 2g cars? Is the transmission the same on all 2gs?
Old May 11, 2011 | 02:23 AM
  #1029
1g FWD : 2791
1g AWD : 3108
2g FWD : 2921 M/T - 2998 A/T
2g AWD : 3157 M/T - 3234 A/T
Old May 11, 2011 | 07:50 AM
  #1030
bbarnhill's Avatar
Below is the exact format that I need. Just fill in your data and you can either paste it in an email or post it in a PM on this forum to me. Ill add it to the next release as long as I recieve it in time. Ill add all the 1g and 2g cars as long as they are in this format. That way I dont screw up and add a car wrong.
<CarMake>Mitsubishi</CarMake>
<CarModel>Evolution</CarModel>
<CarSubModel>5 GSR</CarSubModel>
<StartYear>1998</StartYear>
<EndYear>1998</EndYear>
<Weight>2998</Weight>
<TransTypeManual>true</TransTypeManual>
<TransGear3>1.407</TransGear3>
<TransGear4>1.031</TransGear4>
<FinalGearRatio>4.529</FinalGearRatio>
<DragCoefficient>0.36</DragCoefficient>
<FrontalArea>21.4</FrontalArea>
<TireDiameter>24.8</TireDiameter>
If you need a tire size calculator to figure the tire diameter ... use this one to input the tire specs and get the diameter. This should be using the stock tires. http://www.gtsparkplugs.com/TireCalculator.html
Old May 12, 2011 | 08:16 AM
  #1031
1g DSM M/T
<CarModel>Eclipse/Talon/Laser</CarModel>
<CarSubModel>GSX/Tsi/RS-T</CarSubModel>
<StartYear>1989</StartYear>
<EndYear>1994</EndYear>
<Weight>3108</Weight>
<TransGear3>1.115</TransGear3>
<TransGear4>0.833</TransGear4>
<FinalGearRatio>4.929</FinalGearRatio>
<DragCoefficient>0.29</DragCoefficient>
<TireDiameter>20.03</TireDiameter>
2g DSM AWD M/T
<CarModel>Eclipse/Talon</CarModel>
<CarSubModel>GSX/Tsi</CarSubModel>
<StartYear>1995</StartYear>
<EndYear>1999</EndYear>
<Weight>3157</Weight>
DSM FWD Transmission have slighty bigger gears so if anyone uses these numbers for their DSM, they can change the gears accordingly to the VFAQ page.
Old May 12, 2011 | 10:36 AM
  #1032
project_skyline's Avatar
Hold on, I thought we already had 1g and 2g's in VD?
Or they not input correctly?
Old May 12, 2011 | 12:11 PM
  #1033
I did a fresh download and I only saw a 1g Talon on there.
Old May 12, 2011 | 01:38 PM
  #1034
Weird im seeing 2g eclipse on mine.
Old May 12, 2011 | 02:54 PM
  #1035
Weird. I guess something must have happened with mine to where it wasn't showing up. Mine works now ahaha.
