Virtual Dyno - Standalone Software
Old Mar 27, 2012 | 06:50 PM
  #1396
Creamo3's Avatar
Originally Posted by wizzo 8
I may be wrong but did my whp go up some? Is anyone else showing more HP than before?
My peak went up ~5whp on my last pumpgas log between 1.1.7 (546whp) and 1.1.8.(551whp) with all settings staying the same. I don't recall what the torque was previously
Old Mar 28, 2012 | 05:20 AM
  #1397
bbarnhill's Avatar
Thats due to a fix in the smoothing algorithm that was exponentially smoothing the later parts of the log. Im surprised it wasnt flattening the crap out of the last part of the logs for people.
Old Mar 29, 2012 | 03:00 AM
  #1398
richardjh's Avatar
I didn't notice - I drive a Ralliart! The tiny turbo flattens the crap out of the curve all by itself!
rich
Old Mar 29, 2012 | 04:47 AM
  #1399
bbarnhill's Avatar
hahahaha ... it was hardly noticeable on any graph but it did flatten parts of the graph more than others so it had to be fixed. It caused some to think they were making more power with 1.1.8 and questioned its accuracy. *Sigh* all from fixing a long standing bug.
Old Mar 29, 2012 | 08:34 AM
  #1400
BillSpec's Avatar
So I should updte mine im assuming?
Old Mar 29, 2012 | 05:00 PM
  #1401
bbarnhill's Avatar
If you want the latest version ... if not you can leave your internet disconnected because if it ever connects to the internet it will update.
Old Mar 29, 2012 | 07:59 PM
  #1402
momostallion's Avatar
low priority, just want to mention it in case it hasnt been mentioned:
edit <EndYear>2011</EndYear> to say 2012 in \Virtual Dyno\Cars\Mitsubishi\Evo\EvoX.xml
Old Mar 29, 2012 | 09:18 PM
  #1403
b16a95eg's Avatar
It's late, and I don't feel like searching, so how do I get the RPM to show my full pull? my pull went to 8800. 2byte RPM in my log shows the correct RPM, but the default RPM only showed the 7996 which limited the VD to reading 7907
Old Mar 30, 2012 | 06:03 AM
  #1404
Raptord's Avatar
Delete the regular rpm column in your log so that you only have 2byte rpm left, and add the 2byte rpm column name to the list of column names in the options
Old Mar 31, 2012 | 07:00 AM
  #1405
bbarnhill's Avatar
Just changed it. It will come out with the next car database update.
Old Mar 31, 2012 | 07:01 AM
  #1406
bbarnhill's Avatar
2byterpm isnt a supported column? I thought I had it in there.
Also this shows to only log the columns you need and not every column you recognize.
Old Mar 31, 2012 | 07:25 AM
  #1407
getsideways's Avatar
I have a thought about the smoothing your using, When used it seems to have a more 'averaging' effect , Some people are using it to smooth out huge dips in the road.
I have no technical way to say this as im not computer literate, but it seems if the smoothing could focus on a narrower band of RPM you would have less people making the mistake of posting up graphs with a smoothing of 8 just to cover up a dip in the road that is creating a 100 HP spike...
Im not upset in the least bit, i usually look at my graphs on 1 and smooth them to 2 to get rid of the little stuff in the road so its not a problem personally, But has caused some to question the programs accuracy when in fact its user error.
Old Apr 1, 2012 | 07:59 AM
  #1408
Raptord's Avatar
Little bug I noticed Brad:
If I have "show maximums" enabled, then toggle data points on, then back off again, the maximums will also disappear even though they are still enabled. I have to go to the options, turn them off, save, then turn them back on again.
Old Apr 2, 2012 | 09:23 AM
  #1409
Ian0611's Avatar
Not sure what you did Brad but with the latest update I no longer have to use Administrator privileges to open the program on my work laptop with Windows 7 so thank you for that!
Old Apr 6, 2012 | 10:03 AM
  #1410
90zcrex's Avatar
Hey Brad, first I want to say awesome job with VD, its a sweet program. I've just got an evo 9 and it works fantastic. I do have a question tho, what does your program look for in the csv file to open in VD? I have a honda and datalog with a program called ecucontrol. It datalogs a file very close to that of evoscan with the RPM, TPS, and TIME as the top columns and then the data going down. I tried loading a log into VD but it keeps saying no wot data. I tried moving the TPS column to the same column as a evoscan datalog but it still won't read. I can send you the datalog to look at if you like, If I can use VD on my honda that would be awesome. Thanks
