Virtual Dyno - Standalone Software
This sounds just from the brief reading Ive done to be an issue with Evoscan ... if we could pinpoint what it is from the data then maybe we could approach hamish about it and see what he could do. Im sure he would love to know if there is a bug or glitch. Thats how programs get better. Pinpointing the issue though is the trouble.
I just looked at that graph you posted again and its not that bad @ 1 smoothing ... post the same run with 5 smoothing and I bet you will see a huge difference. I have to agree with Boosted_Tuning on this point. I would be VERY suprised if 20 smoothing on this run were choppy.
Left column being resized would cause the controls to be messed up. I have contemplated docking and undocking the side bar so it could collapse and expand. It just wouldnt be adjustable.
I dont think its going to make it into 1.0.8 ... I need someone to beat the hell out of 1.0.8 for me. Who will give me feedback?
Before I make any suggestion, I should admit that I am not familiar with GUI programming at all, I have only experiences with EE engineer stuffs like C++ or MATLAB.
If you can leave the inner control box size fixed, and let the portion of left and right column changeable, is it still going to make problems?
Since left column area already has horizontal scroll bar, I don't have problem seeing the whole contents, but very minor stuff.
Thanks again for the great program!
Is there a right click option that can be added to tell the software what columns to graph ? A lot of us have boost or AFR labeled as something other than what the software will recognize to properly graph these items.
Just go into the options menu and add the title of the column to the custom column names.
ace33joe: The side bar uses whats called a FlowLayoutPanel and those are a little bit of a pain but if they are called for which that side panel is a call for one ... they work good. The only trouble I have with them is that if I resize them bigger than what my control needs to be it starts looking funky with that custom control. It leaves too much on either side of it and starts looking really crappy. I dont know how to explain it but it really looks bad. I have tried thinking of ways to get the side bar collapsable because that would give you the maximum graph size.
Jason@SpecOps: They are correct in adding them to the custom column names on the settings screen. If they are defaults that the logger records let me know because I want to support all the stock column names.
I've got some feedback:
instead of having to go and right click and hit run as administrator everytime I open the program to be able to save stuff, just make it always run in that mode from the get go.
there were some other issues I had with it, but i'm not in front of my laptop right now, and don't have access to the program. that was my biggest complaint though.
v1.0.7 i started getting the message today
ERROR: input string was not in a correct format
i didn't do anything different from one log to the next. now every new log i input gives me that message.
Also not sure why this needs admin privileges anyway (having not ever used the program) doesn't it simply open files and then save another file back?
