Virtual Dyno - Standalone Software
Old Jan 3, 2011 | 05:25 PM
  #751
BoostedFury's Avatar
I made them full read/write access and it still gave me the error.
I tried running the VD in admin mode and it worked now.
Old Jan 3, 2011 | 05:46 PM
  #752
03RRVIII's Avatar
hi,
I installed the new version, and started to have some issue opening it. But Thanks to tscompusa for helping me fix that issue..
And now i get this error message everytime i click on anything. What could this be????
Thanks!
Old Jan 4, 2011 | 12:15 AM
  #753
germanracing's Avatar
Originally Posted by bbarnhill
Boosted_Tuning is correct ... it is WHP
Ah, that makes sense!
Out of interest: Is there a common factor you can multiply it with to get crank hp for the X MR? (example: say 300whp x 1.25 = 375crank)
Old Jan 4, 2011 | 05:34 AM
  #754
bbarnhill's Avatar
I have no idea due to every car being a bit different. I couldnt find that information on all the vehicles hence the reason the option doesnt exist. I figure its not that hard to convert by hand for the small few that need crank HP (which in my opinion doesnt matter since it doesnt count till it hits the wheel).
Im betting someone on here knows the drivetrain loss factor ... who will chime in first is the only question. Got to love this forum.
Old Jan 4, 2011 | 05:35 AM
  #755
bbarnhill's Avatar
Ohh yeah and that. I am really hoping that 1.0.8 fixes that problem but we shall see. It installs and works on all my machines and a few tuners machines so ... no errors like that yet.
Old Jan 4, 2011 | 05:37 AM
  #756
bbarnhill's Avatar
Originally Posted by 03RRVIII
hi,
Thanks!
That is more than likely a string of data in your file is not able to be converted to a number at some point. Send me your log and Ill find it and let you know. Its easy for me to find it if I run it through the debugger, as it tells me exactly what string broke it.
bradbarnhill at hotmail com
Old Jan 4, 2011 | 07:31 AM
  #757
Raptord's Avatar
Drivetrain loss is somewhere between 21 and 24% if I remember correctly, so dividing by .78 should get you an idea of numbers at the crank.
Old Jan 4, 2011 | 08:55 AM
  #758
Smile
Cheers for that!
Wow, that would make it 392 crank hp, not to shabby...
But from what I've heard a dynojet is braked less than one of our german dynos and gives higher numbers... So maybe that's only about 370hp or less, but still very respectable for a X MR...
In closing, I'd like to add: VROOOOOOOOOOOOOOOOM!!!
Old Jan 4, 2011 | 09:04 AM
  #759
Mellon Racing's Avatar
we could devote an entire thread to drivetrain loss theory. I've not seen any facts posted where someone tested on an engine dyno then on a chassis (awd) dyno for direct comparison in the states. That data may be readily available overseas where I don't so much surfing though.
I have to wonder if a fixed percentage would work though, higher rpm and higher power = more heat, more heat = more loss??
Old Jan 4, 2011 | 11:06 AM
  #760
Boosted Tuning's Avatar
Please dont worry about crank/flywheel numbers. They dont matter.
Old Jan 4, 2011 | 11:29 AM
  #761
bbarnhill's Avatar
I have to agree with both mellon_tuning and boosted_tuning. One its different per car and it is inaccurate to use a fixed number for conversion. Now will it vary that much that a set number cant get you close ... no. BUT ... its also a little useless since it only matters how much you can get to the ground not what your engine puts out. This program will show WHP and if you need to calculate crank hp for whatever reason, you can find the multipliers online somewhere. Hope these two great contributors helped out. I trust both of these guys as they have helped me out tremendously.
Old Jan 4, 2011 | 01:57 PM
  #762
I agree that WHP is a far more useful number to know, unfortunately over here in germany most/close to all power numbers are measured in crank-hp... Don't ask me why, that's the way it's always been... (A dyno will measure the power while accelerating and then measure the drive train loss while decelerating)
So everybody is used to it and for "us" it's easier to compare that way...
It's a bit like if your speedo suddenly read in KPH instead of MPH...
Then again, I can go 260kph/160mph ANY time I choose to (without going to prison ), so it's swings and roundabouts... ;-)
Old Jan 4, 2011 | 02:29 PM
  #763
FWIW the stock evo 8's were rated at what 276bhp? the typically but down about 240awhp. that's about 13% DTL, nowhere near the 21-24% some AWD guys guess. On rwd cars the old rule of thumb was 15% but I'm not sure if that still holds true with modern drivetrains which may less resistant.
Old Jan 4, 2011 | 03:24 PM
  #764
Maybe, but don't most stock evos stray upward in terms of power?
Old Jan 4, 2011 | 05:59 PM
  #765
pug206's Avatar
Can someone make a graph of my car?
I can not use Virtual Dyno
Is Evo IX in 4ª gear wheels with 17 " driver 100kg (220.5 lb)
Thanks!
The file
http://www.megaupload.com/?d=L1RLMZD0
