Virtual Dyno - Standalone Software
Old Mar 30, 2011 | 06:00 AM
  #931
Boosted Tuning's Avatar
Originally Posted by dimacoupe
1.5bar boost and only 285 hp log in attach
thanks and sorry for my english
You do have it on the Mustang dyno setting, the lower reading setting. The Dynojet setting will read higher and is the more commonly used setting.
Old Mar 30, 2011 | 06:10 AM
  #932
dimacoupe's Avatar
but! we have other evo with like my config.
1.3 bar boost
303 hp.
and on my grapр torque and horsepower do not intersect
Old Mar 30, 2011 | 05:00 PM
  #933
bbarnhill's Avatar
Make sure that your graph settings are set the same. I see you are using Nm for the torque format on this particular graph.
I know you have two similar evos but if you log them both and one makes less power in Virtual Dyno ... I promise you it makes less power and will show that on a Dynojet or Mustang dyno as well. Also two identical cars with the same parts on it will also make different power. Also keep in mind that when you make a run in whatever logger you are using, to get more than one run. Some runs are better than others and that is why even on a dynojet or a 4 wheel SuperFlo dyno like we used at my old work, they grab multiple runs to compare in case one is just a bad run. You compare a couple at a time before just claiming you made X amount of horsepower. Look for a consistent looking graph and that will back your claim.
Just because a part says it adds +20hp doesnt mean that VD will show a 20hp increase. That is just marketing hype and a lot of the time the numbers they claim it will add are overly inflated. So please elaborate on your problem and maybe it will become more clear. As of right now these are the only things I can offer for advice.
Let me know if I can help more as I am always here to help or find help for you.
Old Mar 30, 2011 | 05:10 PM
  #934
milford's Avatar
i did some VD pulls right after being on a mustang dyno. The 3 VD pulls were nearly identical to the numbers i was making on the Mustang. They were within 3-6 hp from my actual Mustang numbers.
Old Mar 30, 2011 | 06:02 PM
  #935
VD in Mustang mode right?
Old Mar 30, 2011 | 06:07 PM
  #936
milford's Avatar
yes in Mustang mode. I was shocked to see such similar results. Great product!
Old Mar 30, 2011 | 07:31 PM
  #937
Nice. Glad to hear the results.
Old Mar 31, 2011 | 11:00 AM
  #938
bbarnhill's Avatar
Glad you like it. Ill keep writing on it if you keep praising it like that
Old Mar 31, 2011 | 11:42 AM
  #939
wizzo 8's Avatar
1.3 bar boost
303 hp.
I thought hp and tq are supposed to cross all the time at about the 5250rpm mark. Or is it different if graph is in NM?
Old Mar 31, 2011 | 05:23 PM
  #940
bbarnhill's Avatar
you are correct on both points.
Old Mar 31, 2011 | 05:46 PM
  #941
tscompusa2's Avatar
this programs so dead on its silly.. i was tuning a guy remote on a dynojet and i asked for his logs and i put them in the prog said the numbers and the dyno operator was like "how the hell did he know the numbers? i didnt even tell him" LOL. it was literally 1-2whp off.
Old Mar 31, 2011 | 06:00 PM
  #942
bbarnhill's Avatar
Hahaha ... I love hearing stories where people are freaked out. Glad to hear that Virtual Dyno is performing well.
Old Apr 1, 2011 | 01:17 AM
  #943
gialla's Avatar
I really enjoy, this is the best one!
Old Apr 9, 2011 | 07:04 AM
  #944
304MR's Avatar
I'm getting the same thing (not crossing). Am I doing this wrong or is it because I'm not tuned?
Old Apr 9, 2011 | 11:45 AM
  #945
304MR's Avatar
It came up with 336hp/280tq seems a little high. Only mods I have are cbe, mbc, ets pipes and front mount,ets intake, 93 oct. Untuned.
