stalling issues
Old Sep 13, 2010, 03:13 PM
  #76
merlin.oz's Avatar
^ JoT, I might have led myself astray there, as I wanted to ensure it cranked at 5* I left the first cell at 5*.
Also, as mrfred and jcsbanks and bez have not posted anything on this from their disassembly work, I figured the first cell was the ticket.
But, as you say, it could just be a single parameter, or a table v temp.
One of those "nice to know" parameters.
Old Nov 11, 2010, 05:49 PM
  #77
wreckleford's Avatar
Old thread but I thought I would add that JOT is right about the 5 degrees when cranking.
Old Dec 15, 2010, 04:26 AM
  #78
Eisen7's Avatar
Some good info here thanks I've had the same problem since upgrading to 96530706 v7. Interestingly my AC idle was perfect when running 90550001 on v5 with the same idle/iscv settings. It never stalled!
I got a big improvement today simply by upping the 'desired ISCV with A/C on' from about 10 to 90. This stopped most of the stalling with A/C on, but it's still doing it occasionally.
Next I'll try the 'trick' posted earlier with the increased timing around idle and see how that goes. I'm running HKS 272's so hopefully these settings are OK.
Old Dec 16, 2010, 03:51 PM
  #79
raasfaas's Avatar
There have been many threads around about this issue and it seemed as if you need to do both software and hardware changes...but now it looks like software is good enough (mivec and idle timing changes)
Gonna give this a shot.
Old Dec 16, 2010, 04:02 PM
  #80
Eisen7's Avatar
I tried adjusting the timing map around idle as per my post above and it seemed to improve things further, but it's still stalling every now and then with the AC on when coasting to a stop
Old Dec 16, 2010, 04:06 PM
  #81
raasfaas's Avatar
what do you have your idle set to with ac on?
Old Dec 16, 2010, 04:09 PM
  #82
Raptord's Avatar
Depends on what is causing your idle trouble; if the issue itself is tuning-related, then yes it can be fixed just with tuning, however if it's mechanically-related, then software changes may only be able to alleviate the symptoms without curing the problem itself. This appears to be the case with my car.
Old Dec 16, 2010, 04:12 PM
  #83
raasfaas's Avatar
^yea that makes sense, I guess it's just a process of elimination...gonna try the software changes first.
Old Dec 16, 2010, 04:25 PM
  #84
Eisen7's Avatar
1150rpm at the moment, but it's not quite managing that when the AC is on. More like 1000. ISCV initial step with AC on is set at 100. Maybe I just need to bump that up more until it's idling at the set value.
Old Aug 1, 2013, 07:24 AM
  #85
samadam's Avatar
I still have idle issues. Just installed fic 2150cc injectors and fuel trims are -3 low -8 mid. I have tried everything i can think of and nothing is working. please help
Old Aug 10, 2013, 10:42 PM
  #86
Amici2120's Avatar
Stalls when stopped
Evo 8: starts fine, idles at 1000rpm. 1st gear engages fine then upon depressing the clutch and stopping the car stalls. Has nothing to do w AC which is not on. Other posts seem to have this problem only AC.
Issue came out of the blue. We haven't done anything that knowingly would have caused the problem
Old Aug 11, 2013, 05:34 PM
  #87
evos2k2002's Avatar
wow i had same issue but my idle valve control was dirty
Old Aug 12, 2013, 08:28 PM
  #88
Amici2120's Avatar
What to do next?
Where's the idle valve control, what does it look like and how do I clean it?
Help!!!!!!!!
Old Aug 12, 2013, 09:16 PM
  #89
Raptord's Avatar
It's on the bottom of the throttle body, directly below where the upper IC pipe connects to the throttle body. It is black and there are 3 screws in a triangle formation holding it in place. I don't have a picture handy otherwise I've show you.
mr2rr
Oct 21, 2015 05:44 AM
MarkChamorro
Jun 12, 2013 10:08 PM
terrorz75
Evo X How Tos / Installations
Feb 25, 2013 05:21 AM
jparz087
Feb 22, 2013 08:41 AM
LancerEVOmann
15
May 4, 2005 02:31 PM
Quick Reply: stalling issues
