Tactrix Cable
Old Oct 27, 2010 | 09:11 AM
wreckless969's Avatar
Tactrix Cable
I'm not sure this is the right spot as I don't come to this sextion very often but I'm trying to find out what the differences between the different cables are.
I did a search but as I wasn't sure exactly where to look I didn't find with I'm looking for. If you have a link to said thread that would be awesome. Thanks.
Josh
Old Oct 27, 2010 | 03:00 PM
Not as helpful as I was hoping...
Old Oct 27, 2010 | 03:43 PM
5LEEPERISAH23I's Avatar
Josh
what kind of cables you talking about?
the tactrix cable 2.0 or tactrix 1.3?
Old Oct 27, 2010 | 03:59 PM
Well Im trying to see the difference, there are a bunch of 1.3 variants that are cheaper then the 2.0. I just wanna be able to log and tune.
Old Oct 27, 2010 | 06:04 PM
jpuchalsky's Avatar
the differences are .... 1.3R & 1.3D dont come with the license to use ecuflash. 1.3U should take care of what you need unless you need to tune/log evo X
Old Oct 27, 2010 | 06:52 PM
Ok that's what I was mainly wondering, wanted to see if there was any reason to pick up the 2.0 over one of the cheaper alternatives.
Old Oct 27, 2010 | 08:23 PM
fryedchikin's Avatar
There is a bunch of information here which may help..
http://www.evoscan.com/mitsubishi-su...bd2-can-cables
Old Oct 28, 2010 | 02:34 PM
Dallas J's Avatar
Veteran: Army
If buying used then theres also a difference between old-old 1.3u and newer-old 1.3u. The difference visibly being the newer cable has 1 wire going to the smaller connector and older has 3. I have both versions and the 3 wire doesnt seem to work with anything newer then ecuflash 1.29.
Also, with the other cable I have you have to cut pin 9 for the IX. I see you have an 8, but if you used it on a 9 it apparently has a possibility of causing ECU damage.
Old Dec 13, 2010 | 02:46 PM
TurboTJ's Avatar
So which one do you guys recommend for tuning only an Evo IX? I want to log and tune (with evoscan and ECUFlash).
(I have also searched and this is the only thread I could find.)
The 2.0 is pretty pricey....
http://www.tactrix.com/index.php?pag...mart&Itemid=53
Is the 1.3U the cheapest one I can get? Where is the best place to buy it? What options do I need to select when buying it?
http://www.evoscan.com/evoscan-gps-o...flashing-cable
Thanks for the help!
Links appreciated!
Old Dec 17, 2010 | 06:05 PM
TurboTJ's Avatar
Links appreciated!
Anyone??????
Old Dec 19, 2010 | 02:50 AM
ODUB's Avatar
1.3u
Old Dec 19, 2010 | 09:46 AM
AKAweasle's Avatar
who has the gps data logger thing? i was looking at getting a cable soon and was wondering how helpfull that was? does it mount just suction cupped to the window or can i get it mounted perminantly?
Old Dec 20, 2010 | 01:09 AM
TurboTJ's Avatar
Will a 2.0 still work on an 06' MR for flashing and datalogging?
Old Dec 20, 2010 | 02:56 AM
ODUB's Avatar
the 2.0 will work, but it's not necessary. the 1.3U is good for the 8 or 9. if you're not going to be logging/flashing an EVO X, the 1.3U is what you need. from what I read, the 1.3U is still faster for the 8 and 9 as well.
twisty
Jul 15, 2016 11:01 AM
Mcamacho
Lancer Troubleshooting
Apr 10, 2015 09:29 PM
Braydo25
Lancer Engine Management / Tuning Forums
Jun 2, 2010 07:52 PM
blaze_125
Oct 24, 2009 07:36 AM
EVO8YOU
Dec 15, 2008 04:39 PM
