Speed Density 2.0 (3D VE Tables, Baro)
Old Apr 24, 2011 | 08:07 AM
  #301
VGergo's Avatar
thank you ! will try the rom tomorrow !
Old Apr 24, 2011 | 11:02 AM
  #302
golruss's Avatar
Originally Posted by RoadSpike
Clearly some people are having trouble grasping this relatively simple patch so i'll just draw it out for them picture are worth a thousand words right?
As you should be able to tell the Map volts vs kpa should always be 1:1 so you don't screw up the other table axis. What will happen is you'll measure 40kpa or something and it wont match to the point on the table because its not aligned.
If you want to effect load you do that with the kPA vs Load table while this should have been obvious I guess its not.
https://www.evolutionm.net/forums/at...d-94172715.zip
The link for the above is corrupted, could you check it please.
Old Apr 24, 2011 | 11:29 PM
  #303
RoadSpike's Avatar
I think tomarrow what I'll do is post the roms directly to the site unzipped so we don't have this issue anymore. Thankfully the forum admins have recently allowed large direct posting of rom images.
It will be late in the day tomorrow when i get back from work so please stay tuned
Old Apr 25, 2011 | 08:06 AM
  #304
Drifting Away's Avatar
I cant wait to test this out, good work roadspike.
Old Apr 25, 2011 | 04:29 PM
  #305
golruss's Avatar
No prob... thanks.
Old Apr 25, 2011 | 05:54 PM
  #306
RoadSpike's Avatar
Ok posted all the links again on page #1
https://www.evolutionm.net/forums/9050038-post1.html
Now the bin files are direct downloads but the xml files still need to be zipped hopefully it will be ok with just just 1 file in it though.
Old Apr 25, 2011 | 06:13 PM
  #307
golruss's Avatar
Works fine for me.
Thank you.
Old Apr 26, 2011 | 09:31 AM
  #308
utripin's Avatar
Help, 3d table isn't showing
96531706, added all of the zip files. lost...please be nice.
Old Apr 26, 2011 | 09:37 AM
  #309
RoadSpike's Avatar
That romID isn't a 3D SD version so of course it wont be in 3d
Old Apr 26, 2011 | 09:55 AM
  #310
VGergo's Avatar
With only SD Jitter fix enabled and the Warm up table set as shown my car drives almost flawless, I was not sure if I felt it on the way home had to look on the log to make sure saw it once in a 16ml drive.
I test it ! Much better mabye some jitter at 2000-2100 rpm sometimes
Update : I went an other 50km with the 9653 3d sd rom and I can say it is liveable ! I had 5x jitter and only at 2100 rpm part throttle 4th and 5th gear acceleration . The warmup table like Golruss posted, and all of the jitter fixes turned on .
Old Apr 26, 2011 | 11:57 AM
  #311
utripin's Avatar
My bad
I see,,,,BIG THANKS to you sir for all your work!
Old Apr 26, 2011 | 03:31 PM
  #312
golruss's Avatar
Thats about how it is for me now, I definately can live with this until a fix is found.
thanks again RoadSpike
Old Apr 26, 2011 | 04:42 PM
  #313
RoadSpike's Avatar
Have you guys tried using just 1,3,and 4 jitter fixes and see if its makes a difference?
There is a spot in the code where the multiplier could possibly skyrocket with jitter fix #2 and putting back to stock will ignore that.
Old Apr 26, 2011 | 05:04 PM
  #314
golruss's Avatar
Will try it tomorrow.
Old Apr 27, 2011 | 05:46 PM
  #315
golruss's Avatar
Tried it this morning on my way to work, did not drive as smoothe as when jitter fix #1 was disabled, so I went back with just Jitter fix #3 & #4. Thats how I will drive until a permanent fix is found.
Thanks
