Speed Density 2.0 (3D VE Tables, Baro)
Ive been dialing in a 2D SD rom lately.
MUCH harder to dial in, by the way... Maybe I'll give the new combo of fixes a try soon and report back. Are any others seeing the issue any more with And's combo of fixes?
I seem to get it very, very rarely, nothing like before. One thing I did notice my idle is way better and no throttle hang and my timing is not jumping around so much at idle.
Using Jitter 2,5&6 enabled. Anyone tried a different config.
Are you guys using the original jitter fixes?
Maybe we've gone from ipw burst to drop out like the original jitter bug.
The only slight issue now is hot starting (after car has been run for a while then I stop and the start after a few minutes) from the heat soak in the temp sensor as the cars rpm drops and stalls but only for about 20-30 seconds and then all back to normal again
here's my rom, just to let you know the car is a 2.3 stroker, with RC1000's, MR turbo 3in exhaust, kelford 264 cams, no aircon, 3port, ruinning 2bar @3500
here a dyno plot also on this rom
I have no cold start problems now (after fiddling with various settings) and the car runs great
hehehe thats cause the one the car has 0009 but the rom I had on the memory card with me (which was the same before the patches) didn't have those patches applied and because I uploaded it in work I quickly changed them, I've now corrected it
