Speed Density 2.0 (3D VE Tables, Baro)
Old Apr 27, 2011 | 07:26 PM
  #316
RoadSpike's Avatar
Originally Posted by golruss
Tried it this morning on my way to work, did not drive as smoothe as when jitter fix #1 was disabled, so I went back with just Jitter fix #3 & #4. Thats how I will drive until a permanent fix is found.
Thanks
Man this problem is super annoying hehe!
Maybe i should work off the assumption that the problem happens during an interupt to the main process. There are a couple places in the code where the main load variabld which i'm calling SD_Load2 gets overwritten partway in the larger sub for the CAS routine.
Perhaps whats going on is the program is getting interupted sometime when this variable is overrode into a new value causing the problem. Both places are a short time later rewritten back to the correct values a short time later..
So for giggles lets just stop them from writing the values for now
<table name="SD Jitter Test #5 (Stock 0x2B02 -> 0x9)" address="277B6" type="1D" level="1" scaling="Hex16"/>
<table name="SD Jitter Test #6 (Stock 0x2B01 -> 0x9)" address="27808" type="1D" level="1" scaling="Hex16"/>
Old Apr 28, 2011 | 12:28 AM
  #317
And's Avatar
And
just a quick question I thought the original Jitter fix 1 was a combination of both the jitter fix 2 and 3 allowing better control, at the moment I find that jitter 2 give me the best results and removes all of the jitters and I only suffer from this one cough now and again.
I'll try setting both these (5&6) and see what happens, are they supposed to be enabled with any of the others?
Also in my rom the value in patch 6 is 2B01 should i have been expecting 2b02? like in 5?
Andy
Old Apr 28, 2011 | 12:40 AM
  #318
RoadSpike's Avatar
Andy
Whoops that is a typo on my part the stock value for #6 is 2b01 didn't even notice becuase 5 and 6 are so close.
I must admit now that i'm looking at it #5 is definitely the MOST wierd one out of the lot i've seen it throws a whole long into the ram space not just a word value perhaps its responsible for adding a bit on the top making that value double.
Old Apr 28, 2011 | 07:52 AM
  #319
3gEclipseTurbo's Avatar
Im still DD with non of the jitter fixes, just gives me a reason to cruise at 3k rpm and hit boost alot lol.
Old Apr 28, 2011 | 12:53 PM
  #320
And's Avatar
And
well some good news I've been driving around today for about an hour or so with jitter 2 and 5 and 6 and so far so good no signs of the cough/jitter that i've previously had, will keep on trying it for the next few days and see how it goes
Andy
Old Apr 28, 2011 | 06:14 PM
  #321
golruss's Avatar
Andy
Ok will try it with only #5 & #6 enabled on the way to work tomorrow and let you guys know also.
Old Apr 28, 2011 | 06:43 PM
  #322
drifterific's Avatar
5 and 6 gave me very minimal stutters and I noticed when I enabled 1,5, and 6 that I got more stutters. Im going to try 2,5, and 6 tomorrow on the way to work.
Old Apr 29, 2011 | 10:10 AM
  #323
golruss's Avatar
Thanks 5 & 6 gave me the same results too, will try ANDs way 2,5&6 this evening.
Old Apr 29, 2011 | 10:48 AM
  #324
RoadSpike's Avatar
haha well at least the thing is consistant. Be nice if we come to an appropriate set of values that works everytime.
Old Apr 29, 2011 | 01:09 PM
  #325
poncho8667's Avatar
I'm having issues with the Rom when I scroll through it using ecuflash, it gets about half way down the list of items and closes on me. I didn't know if I need to modify the xml or... Any help would be great.
Thanks, Ben
Old Apr 29, 2011 | 01:14 PM
  #326
RoadSpike's Avatar
Thanks, Ben
Definitely something going on with the xmls if the definitions don't show up right. On page 1 i have links to them and the base xmls required.
Old Apr 29, 2011 | 03:44 PM
  #327
golruss's Avatar
Thanks, Ben
Did you unzip the attached xmls and place them in the open ecu xml folder?
Old Apr 29, 2011 | 08:52 PM
  #328
2.5.6 i felt a few more stutters than when I only had 5 and 6. Im going to try 3.5.6 tomorrow and report my findings tomorrow.
Old Apr 30, 2011 | 05:51 AM
  #329
And's Avatar
And
Thanks, Ben
what you need to do is open the 96530706-v7 xml in a notepad and search for address=0 and then remove it, this should then stop the crashing.
Andy
Old Apr 30, 2011 | 08:22 AM
  #330
poncho8667's Avatar
Andy
Thanks! I will try to find it today!
