2.3ltr Timing Maps
Old Mar 1, 2011 | 06:38 PM
widge's Avatar
2.3ltr Timing Maps
Hey Guys,
Im just about to finish building my 2.3ltr stroker and will be running it in
I have a very conservative 2.0ltr timing map on the car right now, just want any pointers for going 2.3ltr
Also has anyone ran into Knock Sensor dramas with a built motor?
Cheers
Old Mar 1, 2011 | 07:51 PM
tscompusa2's Avatar
Originally Posted by widge
Hey Guys,
Cheers
yes you may have to tweak your knock sensor settings. really depends on the specific build tho. strokers are great fun.. enjoy it.
Old Mar 1, 2011 | 08:08 PM
okevolutionVIII's Avatar
I'm new to this but would this map be a good start for a 2.3L and IX turbo?
Old Mar 1, 2011 | 08:19 PM
tscompusa2's Avatar
no dont use that map for a base map.. just look at 0 to 100 load for reference.
also.. that map is a bit conservative in the cruise area also.. the car will run 38-40* no problem in the cruise area
i will edit that pic so people dont try to copy it.. on the WOT side lol.
Old Mar 1, 2011 | 08:41 PM
Ok, I'm mainly looking for a good starting point for idle and low rpm driving to get some logs for a remote tune.
Old Mar 1, 2011 | 08:44 PM
tscompusa2's Avatar
a remote tune should include the base map. you shouldnt have to do any tuning on your own.. that defeats the whole purpose of a remote tune
Old Mar 1, 2011 | 08:55 PM
This is a car that will be started for the 1st time in 3 years with lot of new mods so I will not be doing any "tuning" myself, just making sure everything is in the right ballpark when I 1st start/drive it.
Old Mar 1, 2011 | 08:59 PM
tscompusa2's Avatar
start it up with the regular map then.. it wont hurt anything.
Old Mar 1, 2011 | 09:46 PM
widge's Avatar
Im going to use some Detcans when this gets tuned.
I have done some reading that a 2.3ltr wont need as much timing (wont take as much) as a 2ltr.
So my run-in tune has cruise around 35-38, and timing ramping down to 4degrees at peak boost ramping to 8 up top, although i wont be hitting full boost until the motor has ran in and its on the dyno,
Full boost being 280load @5000rpm on pump i plan on running some more boost with this new build also, thats just the info from when my 2ltr was running
Old Mar 1, 2011 | 09:56 PM
Benja's Avatar
I'm sure you can get more than 8* in there...
So the head was ok?
Old Mar 2, 2011 | 12:13 AM
And's Avatar
And
are you running SD or the MAF if you PM me you email address I'll send you my rom from my 2.3 so you can have a look through it
Old Mar 2, 2011 | 12:25 AM
widge's Avatar
Im running MAF atm
No the head wasnt ok, everything is getting replaced and machined etc
the only thing old is the head itself and the block everything internal is getting replaced
Yeh give me a quick look at your map widge_86@bigpond.com
Old Mar 2, 2011 | 12:33 AM
And's Avatar
And
email sent
widge
Feb 13, 2022 04:35 PM
dawidevo
Oct 9, 2013 01:20 PM
widge
Oct 1, 2013 03:41 PM
widge
Apr 1, 2011 11:07 PM
Indy Evo
Feb 22, 2009 06:33 AM
