how to log a pull in evoscan?
Old May 30, 2011 | 01:44 PM
taylorgang's Avatar
okay I know this is probably an extremely noob question and I know this isnt the "evoscan forums" but I've been looking for a while and haven't figured out the basics of logging a pull...
I have a tactrix 1.3 cable and I've used evoscan to read the ECU and bring up the maps. I had a friend log a pull on his laptop with his cable, but when I tried it recently I couldn't get it to work.
what are the exact steps to logging a pull?
also do most of you start logging right when you turn on the car? or do you log ONLY from 2-7500 rpm?
Old May 30, 2011 | 01:53 PM
dac001's Avatar
2ed post https://www.evolutionm.net/forums/ec...-tutorial.html
Old May 30, 2011 | 01:57 PM
btmboards's Avatar
when you are plugged in and car is running. what happens when you hit "Start Datalogger"
taylorgang's Avatar
Originally Posted by dac001
^thanks
Old May 30, 2011 | 02:30 PM
taylorgang's Avatar
when youre using virtual dyno do you just cut/paste the section from 2-7k rpm into a new graph and load that into vd?
nvm i got it
Old May 30, 2011 | 02:46 PM
milford's Avatar
no you dont have to do that.. a few seconds before and after the wot pull dont matter. just open VD and choose the log and your done.
Old May 30, 2011 | 05:13 PM
Kakihara's Avatar
do you really want the basics ?
get in 3rd or 4th gear
slow down to under 2000rpm, not above..under 2000rpm
accelerate until just before your rev limit
download virtual dyno, drag and drop the .csv in the software
set up your vehicle weight, the weight of all passengers including the driver
select a smoothing number on the right until your curve isnt too bumpy
btw evoscan usb cables are fragile dont bend the connector too much or it can cause bad connection to the ecu
Old May 30, 2011 | 08:11 PM
taylorgang's Avatar
yeah I figured it out... thanks for all the replies haha
the previous log I had contained 2 wot pulls so when I pulled it up on vd it got all jumbled... thats why i was confused
jdm-vr4
Mar 11, 2014 09:14 PM
EriCS
Sep 6, 2013 06:34 AM
evodziobak
Oct 25, 2011 05:17 AM
MalibuJack
May 28, 2008 05:48 PM
