General non-information about factory ALS
Old Jun 5, 2012 | 10:44 AM
  #361
Maikumaru's Avatar
Right I understand that...same thing happened with me...
map switch does not work like on/off for als
I just gave up on the map switch. I dont know the reason, it is on lancer register and geek mapped the reasons why. Perhaps there is a fix I dont know.
Old Jun 5, 2012 | 02:08 PM
  #362
foxbat's Avatar
SAS isn't switchable...yet. You might want to contact burgers22 in that regard, he was working on switchable sas, he sent me a piece of code to test, V7 but for JDM Evo7.
Ratsbud, did you blank your EGR?
Old Jun 5, 2012 | 02:12 PM
  #363
211Ratsbud's Avatar
Im not trying to switch sas. Im trying to switch to alt maps like normal. Tps works fine, switch died though. Ugh
Old Jun 5, 2012 | 02:46 PM
  #364
Maikumaru's Avatar
Right,
perhaps this pertains or not...
I had one map with negative timing for als/sas
another map without for just standard driving.
Sas will always be on, just without negative timing will do nothing...
I was not able to switch maps (there would be a 30-45 min delay between map switch)
for some reason map switching has not worked...perhaps you are encountering the same problem
Old Jun 5, 2012 | 03:08 PM
  #365
foxbat's Avatar
I see...well a switchable SAS might handy for the future anyway!
I never heard about such issue with switchable maps! Why don't use -ve timing on your main map for now?
Old Jun 5, 2012 | 03:26 PM
  #366
211Ratsbud's Avatar
I just use tps need to put a bal valve on my recirc tube for quick no bpv
Old Jun 5, 2012 | 05:11 PM
  #367
211Ratsbud's Avatar
On overrun with no negative timing, i noticed that pre throttle body there is usually 2-3 psi easily. I need to finish tuning the boost areas of my car, so that I can get things hot and try. I dont think that Im seeing any boost from the SAS yet. Theres something going on with JB/evors's setup. They are opening the valve sooner i think. Im currently just tuning on wastegate pressure which is about 13-14 psi(fp18 wga). I dont plan to raise the boost for autocross at all.. just yet. There is a solo event sunday, which i plan to attend.
There is still a ton of settings left
also on a wot 4th gear pull, sas kicked in with no negative timing afterwards and let an impressive fireball out the back.. such that my entire car was illuminated inside. Im running about 11.7 @ 15 psi so not overly rich but safe.
Old Jun 6, 2012 | 09:42 AM
  #368
Maikumaru's Avatar
I dont know what to say here...this all dosnt make much sense.
How could you have boost pre throttle body without negative timing?
You know it is working most easily by sound...."pop pop pop bang bang".
The valve opens when you lift off the throttle...I have never heard of anyone opening the SAS valve when on the throttle...I dont even know how that happens.
Your fireball is not attributed to secondary air...that sounds like just the result of running a little rich....when air is added to negative timing it is not one pop...it is MANY pops and bangs. Well perhaps if your valve is working as it should it could have aided...but just a single pop is not something I have ever encountered with extra air enabled.
Old Jun 6, 2012 | 09:50 AM
  #369
211Ratsbud's Avatar
It didn't open on throttle, it opened after i lifted but i did nice long fourth gear pull to really heat things. I had a ton of waste gate dump opening on backfires with negative timing.- but on this instance i had none in there.
Old Jun 6, 2012 | 09:54 AM
  #370
211Ratsbud's Avatar
The turbo pushes air at idle, and if you watch your boost gauges on lift there is def positive pressure. Not a lot but some. I will video once i get my false knock tuned
Old Jun 6, 2012 | 05:47 PM
  #371
211Ratsbud's Avatar
Maik, did you ever block off your bpv totally?
I saw some boost above 5 psi easily without my bpv hooked up
Old Jun 6, 2012 | 05:49 PM
  #372
Maikumaru's Avatar
Nope. tried to keep OEM as close as possible
Old Jun 6, 2012 | 06:46 PM
  #373
211Ratsbud's Avatar
I feel that no BPV made a substantial difference, I have a 84mm surge port turbo, which may be more forgiving, but I also use NLTS, so im not lifting for upshifts and slipping the clutch on downshifts seems to reduce the surging/flutter noise associated with no valve. Also, seems to give the best effect yet for sas.
post your timing map and fuel map.. Im getting very consistent pops, and some hysterically loud bass bangs.
Old Jun 6, 2012 | 08:29 PM
  #374
211Ratsbud's Avatar
http://evoecu.logic.net/wiki/TephraM...Alt_Map_status
maik have you tried that logging?
I have a hard time believing that my map switch just stopped working like that. I will have to try the things listed by the evo wiki soon.. maybe to diagnose my issue. TPS is a PITA to switch maps.
Old Jun 7, 2012 | 09:29 AM
  #375
211Ratsbud's Avatar
Installed a second boost guage. I will try to get a video of what i have working tonight
