How Load is Calculated
Old Oct 25, 2011 | 06:19 AM
tephra's Avatar
As they say, a picture is worth a thousand words:
I am not 100% with the algorithm, hell I am not 50% with it, but this should help some people visualise what's going on..
edit - yes that's compressor surge...
Old Oct 25, 2011 | 09:05 AM
mrfred's Avatar
good to see you working on this. so, the plot shows load tracking with the lower of MAP and MAF calcs, but now for the inevitable questions:
- what is this this load used for - table axes and general load-based control of engine function? is it used for the air flow value in the fuel pulse width calc?
- back when i was doing evo 10 disassem, i recall there being uncomp load, baro+airtemp comp load, etc., just like in the 8/9 disassem. the vals were calced from what i call a master load. is the load in your plot one of the compensated loads, the master load, or something earlier than the master load?
Old Oct 25, 2011 | 09:27 AM
Ev0ikon's Avatar
Great! More grayhair for me!
Old Oct 25, 2011 | 09:51 AM
gkania's Avatar
Does it not follow MAF after 5000rpms?
Old Oct 25, 2011 | 10:22 AM
mrfred's Avatar
Ah, you're right. Lighting was poor when I looked earlier. Will edit my post.
Old Oct 25, 2011 | 05:49 PM
tephra's Avatar
As far as I know everything comes from Load_RAW (or your master load).
My log is of the Load_RAW...
I will check the IPW calcs...
Old Oct 25, 2011 | 10:07 PM
Beeble's Avatar
So some logging i did during spool with an underscaled MAF showed Load jumping quite a bit. i couldn't work out if it was the compressor, or it was switching from MAP to MAF. I suspected the latter... but I'm probably wrong
higher RPM it always tracked MAF which was too low
D - if you deliberately OVERscale the MAF, do you think it will still track the lower of the two up top (which would then be MAP)?
Will try and did up the logs...
Old Oct 25, 2011 | 10:13 PM
tephra's Avatar
should do...
The algorithm is a bit more complicated than the "lower" of the two.
I think the main thing is we can log it and then you can see IRL
Old Oct 25, 2011 | 11:41 PM
richardjh's Avatar
By chance, last night, I was going through the function responsible for main fuel map lookup... and was wondering about the load-selection code right there. It compares two load variable values, then applies The Chosen One for use by the fuel map scale.
The annoying thing, I thought, was that it didn't slap The Chosen One into any useful (ie. loggable) address. Quite unusual for the Mitsu code - their stuff usually looks very "debug" friendly, in that you can dip in and catch interim calc results in most places.
I was actually planning on rejigging things so it put "the" fuel load in a more permanent spot (kind of like that old Boost Error tweak), so I could log exactly what was going into the fuel map lookup.
Or was I over-thinking things? That has been known to happen occasionally... ahem...
Rich
Old Oct 25, 2011 | 11:43 PM
tephra's Avatar
Are you talking about the load lookup routine at the top of the fuel map lookup routine?
Old Oct 26, 2011 | 12:10 AM
richardjh's Avatar
Yep. I don't have the code in front of me, but it grabs what I presume are two load candidates, compares 'em, chooses one, and drops it in the load-scaling address.
Edit: Just correcting myself: that subroutine was actually performing checks of a couple of other variables (not a comparison between the loads).
What irked me was that it didn't put the chosen one somewhere I could log, straight off the bat! How rude...
Rich
Old Oct 26, 2011 | 08:13 AM
mrfred's Avatar
Rich
You're correct in your assessment. That piece of Evo 10 code is essentially a direct port of the Evo 7-9 SH2 code.
Old Oct 28, 2011 | 06:19 AM
mrfred's Avatar
dave, any chance i can get you to get a log with the maf 25% overscaled and then another with map 25% overscaled? i think that would give some interesting info on the master load calc without putting your motor in jeopardy. (for those wondering how this can be safe, if the ecu somehow decides to use the higher load rather than the lower, this will cause more fuel to be pushed and cause the ecu to pick more conservative values from the timing map.) perhaps do it at a lower boost and maybe only alter the higher airflow cells so it still runs normally off-boost. i'd do it myself on 3dman1's evo, but atr doesn't doesn't have these loads available for logging yet.
Old Oct 31, 2011 | 05:12 AM
rrkpitt15's Avatar
Is there a reason why the load switches from following the MAP sensor to MAF sensor in middle of a WOT pull?
What is going on when the ecu switches from the MAP sensor to the MAF sensor? Would this cause an inconsistent AFR where the ecu is switching from the MAP sensor to MAF sensor? If this is a problem, is there any way to stop the ecu from switching to the MAF sensor in the middle of a pull aka Speed Density?
I am a newb at all this buy i love learn. Any the only way to learn is to ask questions. Thanks!
Old Dec 10, 2011 | 05:50 AM
zerocooll21's Avatar
Nice work Teph, Sub'd
gccruz
09+ Ralliart Show and Shine
86
Aug 5, 2022 10:31 AM
Thrilla
Apr 23, 2017 01:32 PM
2bar_evo
Oct 25, 2016 07:13 PM
ddejaege
Jul 27, 2014 06:59 PM
mikeywick821
31
Mar 24, 2014 09:47 AM
