what is "Idle Error" table ?
Old Dec 19, 2011 | 12:06 AM
stunt2's Avatar
can anyone explain what do these two tables do :
Idle Error - Normal
Idle Error - A/C On
thanks in advance
Old Dec 19, 2011 | 06:14 AM
Dynotech Tuning's Avatar
+1 on that.
Old Dec 20, 2011 | 10:50 PM
stunt2's Avatar
bump for any input
Old Dec 20, 2011 | 11:24 PM
That RPM scaling cannot be right either. It would make more sense to be multiplied by 3 or 4.
-Jamie
Old Dec 31, 2011 | 08:17 PM
prowakeskater's Avatar
bump for answers
Old Dec 31, 2011 | 10:53 PM
merlin.oz's Avatar
ISCV step change for a given rpm error from target idle rpm.
Old Dec 31, 2011 | 11:26 PM
The rpm scaling cannot be right, can it?
-Jamie
Old Jan 1, 2012 | 01:31 PM
merlin.oz's Avatar
well nobody has specified what is in their definition table, or from what ROM, so I cant say if its right or not.
But,
for an Evo7, the rpm scale should read:
rpm Steps
0____0
62___2
125__4
188__6
250__8
312__10
375__10
438__10
500__10
for an Evo8, the rpm scale should read:
rpm__ Steps
0____0
31___1
62___2
94___3
125__4
156__4
188__4
219__4
250__4
These are both JDM, but I would expect USDM to be the same.
Old Jan 1, 2012 | 01:41 PM
Raptord's Avatar
well nobody has specified whatis in their definition table, or from what ROM, so I cant say if its right or not.
But, the rpm scale should read:
125
188
250
312
375
438
500
That's what I have in my 88590715 map.
Old Jan 1, 2012 | 03:43 PM
I believe mine went up to 250rpm in 9417 bit I could be mistaken. You would imagine that it would go up to actual idle RPM.
Old Jan 1, 2012 | 04:04 PM
Raptord's Avatar
Doesn't need to go up to idle rpm. Unless I'm mistaken, it works sort of like the boost error correction table. If rpm is x away from desired idle rpm, then it adjusts ISC steps/demand by the relevant value.
Old Jan 1, 2012 | 04:27 PM
Hmm, seems like this may be useful for cars that don't catch idle and almost stall during clutch-in decel. This is assuming this table is active u det those conditions.
-Jamie
Old Jan 1, 2012 | 05:00 PM
Raptord's Avatar
-Jamie
I played around with this table trying to fix exactly what you're talking about, and it did make a difference. Increasing the adjustment too much will cause the rpm to overshoot the desired idle rpm.
Old Jan 1, 2012 | 05:15 PM
merlin.oz's Avatar
+1 on what Raptord says, it is active, but dont go mad or the idle will start hunting
PPM
Apr 2, 2015 09:35 AM
AlexEvo6
Oct 30, 2010 10:26 AM
topnotch_EVO
Jun 19, 2010 06:41 PM
NOMIEZVR4
Oct 26, 2009 10:36 PM
mscorei
Aug 26, 2007 09:18 AM
