s2 cams knock tables.
Old Jun 6, 2012 | 07:46 AM
211Ratsbud's Avatar
Should adjusting knock tables be necessary for s2 cams and gsc springs retainers?
Old Jun 6, 2012 | 09:26 AM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/sh....php?p=8078734
I found this.. i will raise my knock load to 120 and try. I get very severe part throttle knock. And i am unsure of toying with multipliers
If anything these s2s sound quiet vs my hks.. i attribute that to bleeding lifters though
Old Jun 6, 2012 | 06:04 PM
JohnBradley's Avatar
Not typically. Lifters are bled properly?
Old Jun 6, 2012 | 06:36 PM
211Ratsbud's Avatar
yes, she is quiet to the ear, I bled them.. i had kind of discovered a "no way its that problem so I wont even try" type of mistake. Skunk2 manifold hogged out by STM + s2 cams.
this is pretty close to all knock gone now. I had taken out too much timing. Im still getting some low load knock, and im trying to compare my hks + stock mani map vs my s2 + s2 map.. and well things arent even close. Im kinda shootin in the dark 200 load all the way! I havent boosted above wastegate yet.
I kind of feel that Im lacking timing seriously, but i think that with a substantial increase in airflow ability that im moving in the right direction.
Old Jun 15, 2012 | 06:54 PM
211Ratsbud's Avatar
is my timing way the hell off here or something? I have tried a lot of things, and I cannot get this light throttle knock to go away!
File Type: zip
Old Jun 16, 2012 | 06:24 AM
Sirnixalot's Avatar
have you tried taking out some overlap?
I am not running the S2's but that solved my knock problem with my HKS 272/280 combo
Old Jun 16, 2012 | 10:55 AM
211Ratsbud's Avatar
Ill have to look into that seems to be consistent below 4200 lol. Its bad like 15+ cts
It wasnt there when i was on maf by any means
Old Jun 17, 2012 | 02:10 PM
211Ratsbud's Avatar
Im not seeing any difference in taking some overlap out. Im seeing cts of 34. this has got to be false.. Doing a ton of research.
I wonder if my Dynomax vt muffler is rattling and causing a bit of the false knock.
Old Jun 17, 2012 | 06:34 PM
211Ratsbud's Avatar
i normally get a -10 like this, and i dont know where it comes from
Old Jun 17, 2012 | 09:47 PM
stunt2's Avatar
that timing jump 34,-10,0,7 seems wierd to me
can induce knock I think
Old Jun 18, 2012 | 04:27 AM
charlie.tunah's Avatar
Do you see the same timing drop on a normal non-als rom? Just wondering of some of the timing mods you've done may be messing things up.
Old Jun 18, 2012 | 05:10 AM
211Ratsbud's Avatar
Im on a usdm rom atm.. with no negative timing
Old Jun 20, 2012 | 03:27 AM
Do you think the -10 is a result of the load spike/jitter? Try logging only load and rpm and see if you see the spike. Is the highest load for that rpm set to -10 deg timing? It seems very similar to what I remember experiencing with the 3d ve 9653 rom. But I wasnt seeing it during a pull, only cruising.
just a thought
PPM
Apr 2, 2015 09:35 AM
Moore Auto
Oct 19, 2012 07:56 PM
NOMIEZVR4
Oct 26, 2009 10:36 PM
mandy1
AEM EMS
Dec 8, 2007 11:05 AM
Mad_SB
Jul 13, 2006 05:18 PM
