New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Jul 8, 2013 | 03:21 PM
  #556
JohnnyTSi's Avatar
Now this would be a kick - @ss feature for the EvoDroid7:
Attached Thumbnails New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review-hud.jpg
Old Jul 8, 2013 | 03:50 PM
  #557
jdmevorory's Avatar
Originally Posted by JohnnyTSi
you must turn on USB Storage mode on the Android device (in Settings on the EvoDroid7)
John-
Does that mean "Enable media scanning on USB"?
If so, that still doesn't work. Removable disk F and G show up on the PC but when I try to open them or send a file to them it says "Please insert a disc into Removable Disk (F or G).
Old Jul 8, 2013 | 06:15 PM
  #558
Gavin Spratling's Avatar
When you get the main page after start up, click on the usb symbol at the bottom of screen, second from left of clock.
You should get a menu with usb connected, click on that and you should get "turn on usb storage" click on that and you should be in business.
Old Jul 8, 2013 | 07:00 PM
  #559
GaugeDesigner
Download attachment
Rename to EvoScanPPCGaugeDesigner.exe
Make sure the file type has been changed to exe
Put in Evoscan folder of Evodroid
Then run EvoScanPPCGaugeDesigner from there.
File Type: hex
Old Jul 8, 2013 | 07:07 PM
  #560
jdmevorory's Avatar
Excellent! Thanks!
Old Jul 8, 2013 | 09:24 PM
  #561
hotrod's Avatar
Download attachment
awesome thanks!!
Old Jul 8, 2013 | 11:45 PM
  #562
jdmevorory's Avatar
Download attachment
Did that but it seems that the evodroid still doesn't see it as a program and doesn't know how to open it. Arg....
Old Jul 9, 2013 | 12:45 AM
  #563
You need to run it from you computer. It is a windows program not an android app, but it needs to be in the evoscan folder and run from there.
Connect Evodroid to your computer, copy gaugedesigner to evoscan folder (if you havent already done it), then from your computer double click on in and it will run on your computer. Same as you would run a program that was on a thumbdrive.
You then design or modify your gauges which are which are saved in the evoscan folder on your evodroid.
Then when evoscan run on the evodroid it finds your new gauges and all is well...... maybe.
Old Jul 9, 2013 | 01:17 AM
  #564
Mick_O's Avatar
Forgive the noob question but does the evoscan work with aftermarket ECU's? I'm running a plug n play Link G4 ecu but like the idea of the evoscan
Thanks
Old Jul 9, 2013 | 02:30 AM
  #565
jdmevorory's Avatar
Originally Posted by bpevo
1. WiFi on the EvoDroid wont connect to PEAP/TLS Certificate based WiFi systems (i.e WPA2 Enterprise - which both my work and home WiFi use ) This might be the version of Android on it (4.0.4) might be the problem there - is there any updates for the Android OS for the EvoDroid?
Does this walk through help at all - http://nickescobedo.com/222/connect-android-to-a-wpa2-enterprise-wireless-network ?
I want to buy a new wireless router and saw that one of them has the WPA2 listed under security and would hate to buy it if it won't work.
Old Jul 9, 2013 | 12:08 PM
  #566
johnnnyjeans's Avatar
hamish, or anyone.
can this tablet work with backup camera video input yet?
and will the screen automatically tune to the camera upon reversing? (assuming the camera's power is tapped into the reverse light power signal and turn when reversing, thus sending signal to the video input cable to tablet, then tablet shows reversing camera screen.)
Old Jul 10, 2013 | 08:40 AM
  #567
evoscan's Avatar
Silver Sponsor
The thicker faster EvoDroid7 USB Charger cables are now ready, they will be dispatched later tonight. Some more EvoDroid7 orders will also be dispatched later tonight.
Old Jul 10, 2013 | 08:43 AM
  #568
evoscan's Avatar
Silver Sponsor
EvoDroid7 connects to your home wifi router if you are close enough, the range is fairly limited. take your evodroid7 for a walk see how you get on. my wifi router is set to wireless-G 2.4Ghz WPA2-Personal.
Old Jul 10, 2013 | 08:45 AM
  #569
evoscan's Avatar
Silver Sponsor
yep the EvoDroid7 can do that.. all I have to do is allow you to see the option in the settings screen "HUD Invert Display" tickbox. and its good if you put a piece of tint film on the windscreen also. then it works well without double glaze ghosting.
Old Jul 10, 2013 | 10:50 PM
  #570
Grimgrak's Avatar
Any word on the double din? Did you order in a jdm double din bezel for test fit?
