New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Jul 11, 2013 | 04:03 AM
  #571
jdmevorory's Avatar
Mine doesn't charge when connected to the PC......
Old Jul 11, 2013 | 04:09 AM
  #572
Mick_O's Avatar
Wow my question was ignored???
Old Jul 11, 2013 | 04:37 AM
  #573
jdmevorory's Avatar
I did NOT know this off the top of my head but I did USE it. About two minutes of using it to do a simple Google search came up with the following:
http://www.linkecu.com/forums/G4Forum/860897503
http://www.geekmapped.com/forums/showthread.php?t=2003
Old Jul 11, 2013 | 09:24 AM
  #574
Cetme's Avatar
Hey Hammish, I PM'd you 2 weeks ago and I havent received a response I was wondering if you could respond. I know you are busy and I appreciate everything.
Wes
Old Jul 11, 2013 | 05:41 PM
  #575
BADFISH6's Avatar
Hamish, have you sent out confirmation emails to everyone or just for the orders you are about to ship? I still havent gotten one. Order #7949. Just wanted to make sure it didn't go into my spam or something.
Old Jul 11, 2013 | 08:39 PM
  #576
hotrod's Avatar
Been doing a little work with the PPC Designer. This is nowhere close to finished but I took the gauge design lilmaynard posted up and modified it a bit to work for me. My EvoDroid is going to be replacing my gauge cluster since my RPM gauge stopped working. I will be testing it a bit tomorrow to see how well the gauges pick up and see if I need to remove any gauges in order to see things better.
The gauge needles are in there when I load it up on the ED and there is a digital speedometer in the center of the RPM area.
Here is a pic...
Old Jul 11, 2013 | 09:50 PM
  #577
hotrod's Avatar
Couple more things...
1. When I try to mess with the template switch buttons on both my design and the standard one on the EvoDroid, it gives me a runtime error. I even edited the template pointer to go to my template. Not sure what is up with that. To get my template to show up, I have to name it 800x480_Carbon1 before it will show.
2. I believe it was lilmaynard that reposted your pinout for the inputs on the DA cable. Can you tell us which is positive and which is ground for the ACC power input? Is it a 12v input?
Thanks again for all of your hard work Hamish! I know even with all your testing, it can't compare to tons of hands on the device and finding bugs. I know with video games they go through tons of testing but bugs always show up anyways.
Old Jul 12, 2013 | 01:12 AM
  #578
limaynard's Avatar
Originally Posted by evoscan
I am putting together the pin diagram now, I will post it up tomorrow on the quick start guide url.
Hi Hamish, did you do this? If so, what's the URL?
Thanks....
  #579
Resi's Avatar
Originally Posted by Resi
Hey Hamish,
I seem to have an issue with the gps sensor on my evodroid. When I open maps, it cannot determine my location unless I enable the "locate by cellular/wifi" option. I have run the gps test app for upwards of 5 minutes, pinging up to5 satelites, but never determines my coordinates. Anyone else having this issue? Any advice as to a possible fix?
-Robert
Bump!
Trouble ticket also submitted. Prompt response would be appreciated!
Old Jul 12, 2013 | 12:00 PM
  #580
johnnnyjeans's Avatar
does the evodroid shows real time boost from ECU or is an external boost tapped in sensor better?
Old Jul 12, 2013 | 04:31 PM
  #581
Gavin Spratling's Avatar
To get a MAP PSI reading you will need an external sensor.
The ECU uses LOAD% and maybe other variables to wok out boost.
It doesn't have a MAP sensor.
Old Jul 12, 2013 | 10:46 PM
  #582
limaynard's Avatar
Bump!
Hi, have you checked location services in settings?
Old Jul 13, 2013 | 06:36 AM
  #583
Jorge T's Avatar
if you have a JDM Map sensor and and ecu mods for it, then yes it will.
Old Jul 13, 2013 | 05:25 PM
  #584
Allen Fong's Avatar
dsm
How hard would it be to get this to work on a 2g eclipse? running ceddy mods
Old Jul 14, 2013 | 11:30 PM
  #585
Resi's Avatar
Yes, my original post has a screenshot of my settings.
