New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Dec 15, 2013 | 12:21 AM
  #946
ExRotary's Avatar
I would like to display my SST transmission temperature. The Mitsubishi EVOX Mode23 USA xml has RequestID="CAN28-0" for transmission temperature. It is not returning any data.
Does anyone know anything about the CAN requests that appear in the XMLs. They do not appear to be related to the standard PID codes for ODBII - see http://en.wikipedia.org/w/index.php?...ldid=302810005. Is there a table of CAN Numbers somewhere? Google is not being a lot of help in this instance.
Old Dec 16, 2013 | 10:40 AM
  #947
JoshB's Avatar
This has probably been answered a couple times, but I have a 2.0 tatrix open port plug I bought for turning my ralliart. I'm really interested in this product but only if the product works with the cable I payed 200$ for already. Would this cable work? (granted I switch the input to micro USB) thank you.
Old Dec 17, 2013 | 12:32 AM
  #948
Santtuboi's Avatar
No, it needs openport 1.3DA or 3.0DA-cable to work :/ 3.0DA for ralliart
Old Dec 19, 2013 | 12:34 PM
  #949
turbotaloon95's Avatar
I've been searching their website. I don't see any way to download the android app and/or purchase the android cable separately. Does anyone know if this is possible? I'd like to use this on my own tablet.
Old Dec 19, 2013 | 11:47 PM
  #950
evoscan's Avatar
Silver Sponsor
Hi turbotaloon95, the cable and software only comes with the evodroid7 at the moment. but, yes you can use the software on your own tablet if you have an evodroid7.
Old Dec 20, 2013 | 09:40 AM
  #951
Grimgrak's Avatar
It's pretty much false advertising to say this thing is a nav. It won't work without wifi and is slower than a ten year old Garmin
Old Dec 20, 2013 | 02:44 PM
  #952
evoscan's Avatar
Silver Sponsor
It is Android v4.0.4, and everything can work without wifi. also old Garmin were only 100Mhz,this is many times faster than that, it is true that maybe old Garmin didn't run a whole o/s like android.
Old Dec 20, 2013 | 04:41 PM
  #953
Grimgrak's Avatar
Sorry thats a flat out lie. I have had 9+ satellites connected and it still hangs for 10+ minutes unable to locate me. If anyone is interested in a video of this let me know.
Old Dec 20, 2013 | 05:51 PM
  #954
evoscan's Avatar
Silver Sponsor
oh, the gps module, you didn't mention anything about that. it takes just the same time for all gps locks on all android devices, they all use similiar gps chips. if it takes that long then the gps module must be a faulty one, please return the whole unit and we will replace it.
Old Dec 21, 2013 | 12:31 AM
  #955
Santtuboi's Avatar
I have to be completely stationary for few minutes for it to locate me. If I start to drive and then switch to Navigon what I use in Evodroid , it can't locate me for long time. No similar problems on anyother android-devices I use. I'm gonna switch to better tablet when I have time and motivation to workout all the problems.
Btw in Google Play, there is mut-protocol for Torque. I could not get it to work in older Evo yet but maybe thats' possible
Old Dec 21, 2013 | 01:48 AM
  #956
evoscan's Avatar
Silver Sponsor
nah, all of my EvoDroid7s get a gps lock in a few minutes, even when moving. that one is faulty, send it back. I will run a full GPS quality control test to make sure every unit before sending out from now on has no faulty gps.
Old Dec 21, 2013 | 02:52 AM
  #957
Santtuboi's Avatar
It probably is software related. Do you have newer softaware that I can flash/update? When I last used gps about 2months ago it located me in less than minute when stationary. But when already moving it takes ages to lock-on. Do you have evodroid specific update part in your evoscan.com site where I can look for soft updates?
Old Dec 21, 2013 | 03:37 AM
  #958
evoscan's Avatar
Silver Sponsor
I imagine that you need to be stationary while the gps device locates the satellites and moving during this phase disrupts the process.
Old Dec 21, 2013 | 08:18 AM
  #959
Grimgrak's Avatar
Now that you've got some time to post how about finishing off the howto sections?
EvoScan EvoDroid7 External Sensor and Wideband Setup Guide #3
http://www.youtube.com/ coming soon...
Download Windows Gauge Designer for EvoDroid7 here
(link coming soon)...
HOWTO: Connect an External Wideband Sensor to stop your pistons melting from Lean conditions causing excessive heat and destructive detonation.
+ Innovate LC1
+ Zeitronix ZT2 | ZT3
+ AEM UEGO
HOWTO: Connect an External Boost Sensor
to stop your pistons melting from Overboost causing excessive heat and destructive detonation.
+ JDM Map Sensor
+ OMNI 3-bar MAP sensor scalings
+ GM 3 Bar MAP Sensor Install
HOWTO: Connect an External Engine Oil Temperature or Transmission Oil Temperature sensor or Inlet Air Temperature(IAT) sensor or Exhaust Gas Temperature(EGT) sensor
to monitor your engine from excessive heat.
HOWTO: Connect an External Oil Pressure sensor
to stop your engine seizing up or stop shaving metal filings from the conrod and crankshaft bearings throughout the engine.
Old Dec 21, 2013 | 11:53 AM
  #960
Santtuboi's Avatar
+ Innovate LC1
+ AEM UEGO
+ JDM Map Sensor
+1
Also how about Plx support for evoscan? Any news on that?
