New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Subscribe
Jan 7, 2014 | 10:05 PM
  #976
How does switching pins disable the battery in the evodroid? I want this thing to die when i turn my ignition off and come on with ignition power.
Swapping pins would simply not drain the car battery.
Quote: You can disable the battery power on any openport cable by putting the OBDII port pin16 on to ACC (key ignition power supply 12-14v) instead of BATT (battery backup fulltime 12-14v)
Reply 0
Jan 8, 2014 | 05:58 AM
  #977
Quote: How does switching pins disable the battery in the evodroid? I want this thing to die when i turn my ignition off and come on with ignition power.
Good point, I will add a new feature to EvoScan for EvoDroid software, so that when the power is removed the screen will prompt "EvoDroid shutting down in 10seconds, press Cancel to stop" and when the power is put back on I will make the EvoDroid7 come back to life... how does that sound?
Reply 0
Jan 8, 2014 | 06:10 PM
  #978
Quote: Good point, I will add a new feature to EvoScan for EvoDroid software, so that when the power is removed the screen will prompt "EvoDroid shutting down in 10seconds, press Cancel to stop" and when the power is put back on I will make the EvoDroid7 come back to life... how does that sound?
That sounds great.
Can we also have the template switching fixed?
Thanks...
Reply 0
Jan 8, 2014 | 09:42 PM
  #979
Like a dream. Oem how it should be.
Reply 0
Jan 9, 2014 | 03:09 PM
  #980
Hamish any chance i could get a new windscreen holder, mine melted we had 45+ degrees for 3 days before christmas and its now a twisted mess!
Reply 0
Jan 9, 2014 | 03:19 PM
  #981
yeah, send me an email.
Reply 0
Jan 9, 2014 | 03:25 PM
  #982
email sent, thanks
Reply 0
Jan 9, 2014 | 04:48 PM
  #983
Quote: email sent, thanks
I have one that I can ship from Sydney...
Reply 0
Jan 11, 2014 | 02:29 AM
  #984
One question:
Does it play Angry Birds?
J/k. Great work! I'm still rocking the old school GPS flasher. Works like a charm even after 3+ years.
Reply 0
Jan 13, 2014 | 12:51 PM
  #985
Is there an updated .apk with significant fixes?
Reply 0
Jan 13, 2014 | 11:00 PM
  #986
I am adding some more features and fixes right now.
Reply 0
Jan 14, 2014 | 04:03 AM
  #987
Do we have to download updates from somewhere or does evodroid support OTA-updates?
Reply 0
Jan 14, 2014 | 04:24 AM
  #988
this might be a little off topic, but id be really keen to run one of these by installing a evo 7 gta trim panel in my evo 8 like the pic here. so i have two questions: does anyone know if the evodroid will fit in this space and has anyone tried to fit this trim panel to an 8? (the existing radio/hvac panel will need to be trimmed to accommodate)
New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review-dsc02283.jpg
Reply 0
Jan 15, 2014 | 09:12 PM
  #989
Follow up question for Hamish. My current set up is an older Erisin Android head unit like this but running Android 2.3:
http://www.erisin.com/erisin-es9001a...-ram_p468.html
If I buy the Evoidroid7 will i be able to install the software and use the cable on my Android 2.3 head unit so I can have the gauges on that screen while I look into retro fitting the 7.5 dash trim as mentioned above?
Thanks in advance.
Reply 0
Jan 15, 2014 | 09:23 PM
  #990
Quote: If I buy the Evoidroid7 will i be able to install the software and use the cable on my Android 2.3 head unit so I can have the gauges on that screen while I look into retro fitting the 7.5 dash trim as mentioned above?
Yes that is correct, you can do that, and it will work. with EvoDroid7 and 1.3DA it will work fine.
Reply 0
16  56  62  63  64  65  66  67  68  69  70  76
