Need HUGE help!!
Old Dec 11, 2012 | 12:45 PM
  #31
rrstlevo's Avatar
Originally Posted by evo62268
Never heard of them... ^I know you from the other site...I is silverbullet2010
Hey man. Brian right? Tom has his own growing business and he knows what he is doing. Search around for him on here he shows up everywhere and I have nothing but good remarks thus far.
http://tscomptuned.net/portfolio.htm
https://www.evolutionm.net/forums/al...uneds-evo.html
Old Dec 11, 2012 | 01:04 PM
  #32
evo62268's Avatar
Yessir thats me. Iwill check them out as im looking for a good tuner as well. Although I may have boostin do it.
Old Dec 11, 2012 | 02:27 PM
  #33
AWDBus's Avatar
Jay at Boosted has been good to me. You will also see hes always willing to help out others. I see his posts in alot of these "help" threads with actually help, not the usual "send me your rom" type you see from a few others.
Old Dec 11, 2012 | 03:28 PM
  #34
domyz's Avatar
^^x2
Jay has the passion. He's always here to help. Customer service won't get any better than that.
Old Dec 11, 2012 | 07:23 PM
  #35
DarkEvo's Avatar
Ok, well as soon as I get the car back Ill upload whatever need be. If this car should truly make over 400 and I'm at 321 and have paid as much as I have so far, I'm not going to be happy.
Old Dec 13, 2012 | 10:40 AM
  #36
evo62268's Avatar
Yes you should be at least 400. My car untuned with just boost controlle k&n and exhaust made 300.
Old Dec 13, 2012 | 12:51 PM
  #37
domyz's Avatar
http://www.youtube.com/watch?v=uXi4SEfnnyw
Hahaha the sound at 0:30... 300whp deserve a
Old Dec 20, 2012 | 06:47 AM
  #38
DarkEvo's Avatar
So what should I see for the max boost from a GT35 on stock internals? Im not sure what the internals can hold hp wise either.
Old Jan 19, 2013 | 04:17 PM
  #39
DarkEvo's Avatar
Ok, got the car back finally. It only made 339.03 awhp and 313.63 tq. That is at 22lbs of boost. He said when he moves the boost controller, manual one, up one click it spikes the boost to 30lbs for some reason so he left it at 22. He also said when he wouldadjust timing and so forth the car would automatically kick the timing back down and just wouldn't allow for much adjustment. The check engine light is still on for a wastegate silenoid and misfire. He said there is no misfire and the wastegate silenoid has no parameters to turn it off. Does anyone know if there is a way to get both those error codes to go away for good so my check engine light can be turned off?
Old Jan 19, 2013 | 08:22 PM
  #40
Raptord's Avatar
You paid a tuner 1000$ and he doesn't bother with figuring out what's wrong with the boost controller or fixing the CELs? I'd never do any more business there if I were you.
Old Jan 19, 2013 | 08:51 PM
  #41
3gturbo's Avatar
My 2g made 350 awhp on a big 16g heh.
Old Jan 20, 2013 | 07:08 AM
  #42
DarkEvo's Avatar
Well I have no intention of ever going back so I want to figure out how to get this corrected.
Old Jan 20, 2013 | 09:59 AM
  #43
nikos_paps's Avatar
if you can send me your rom file and all your car specs and i will try to help you what to change!
Old Jan 20, 2013 | 10:11 AM
  #44
todd6027's Avatar
what are the exact fault codes ???
Old Jan 20, 2013 | 12:15 PM
  #45
DarkEvo's Avatar
I can't seem to connect to get the ROM file. Getting:
[14:10:06.796] J2534 API Version: 04.04
[14:10:06.796] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[14:10:06.796] Device Firmware Version: 1.11.3137
[14:10:06.796] Device Serial Number: TA3h8D97
[14:10:09.062] sending init sequence 1 (0001)
[14:10:12.265] sending init sequence 1 (0003)
[14:10:15.468] sending init sequence 1 (FFFF)
[14:10:18.171] no response to any known code
[14:10:18.171] interface close
[14:10:33.265] J2534 API Version: 04.04
[14:10:33.265] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[14:10:33.265] Device Firmware Version: 1.11.3137
[14:10:33.265] Device Serial Number: TA3h8D97
[14:10:35.140] sending init sequence 1 (0001)
[14:10:38.343] sending init sequence 1 (0003)
[14:10:41.546] sending init sequence 1 (FFFF)
[14:10:44.250] no response to any known code
[14:10:44.250] interface close
[14:10:53.343] J2534 API Version: 04.04
[14:10:53.343] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[14:10:53.343] Device Firmware Version: 1.11.3137
[14:10:53.343] Device Serial Number: TA3h8D97
[14:10:55.031] sending init sequence 1 (0001)
[14:10:58.234] sending init sequence 1 (0003)
[14:11:01.437] sending init sequence 1 (FFFF)
[14:11:04.140] no response to any known code
[14:11:04.140] interface close
