Gear dependent boost control
Old Dec 9, 2014, 07:06 PM
hearnoevo's Avatar
For those running tephra, how much boost aka WGDC do you run in 1st and 2nd gear compared to 3rd? I've always tuned the car in third and called it a day, but would like to increase my boost in 1st and 2nd gear since I've switched to using tephra if it's safe to do so.
Old Dec 11, 2014, 08:22 AM
idkmybffjjill's Avatar
i usually leave 1,2,3 pretty much the same and only really change 4 and 5.
Old Dec 11, 2014, 09:42 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
just do logs. you typically need more wgdc in 1 and 2 since the engine accelerates faster than the turbo spools. then you have 3 rd gear. Then you run less wgdc in 4 and 5 since the engine accelerates slower than the turbo in those two gears, and the increased load can cause overboost.
mrfred
Mar 11, 2015 10:32 AM
Femi
AEM EMS
Jun 11, 2009 07:29 AM
Nurburgring
Feb 17, 2009 12:38 PM
Mr. Evo IX
Jun 9, 2008 09:43 AM
kamak
Dec 9, 2006 03:00 PM
Quick Reply: Gear dependent boost control
