MIVEC tuning
Old Oct 8, 2007 | 05:48 PM
  #376
Jeff_Jeske's Avatar
Close.... 50-70 load at 2500 rpm cruise at 25mph.
I have confirmed that the car only feels this way with the more aggressive mivec map.
The new mivec map puts me in the 30* range where it used to be 14-20*.
Stock:
https://www.evolutionm.net/forums/at...4&d=1187972572
Old Oct 9, 2007 | 06:51 AM
  #377
Jeff_Jeske's Avatar
Well I logged my issue this morning. Its when I first go into second gear and cruise at 2500-3000 rpm. Load is around 50. For some reason my timing doesn't advance like it should. I see 8-10* instead of 20-30*.
Old Oct 10, 2007 | 09:03 AM
  #378
LostSolVTEC's Avatar
probably a temp issue since the motor's cold to stop you from blowing it up before it hits operating temp.
Old Oct 10, 2007 | 09:09 AM
  #379
Jeff_Jeske's Avatar
I'm not sure about that. With a load of only 70 I'm simply cruising down the street. It only happens when the mivec is advanced beyond the stock level. Keeping everything else the same and putting my stock mivec map in the issue is corrected. I'm tempted to reduce the mivec at those load areas as I doubt it will make that much of a difference anyway.
Old Oct 10, 2007 | 11:40 AM
  #380
fastrob691's Avatar
The computer on Honda motors will not allow vtec until certain parameters(temp,etc) are met, maybe this is the same thing going on, just an idea.
Old Oct 10, 2007 | 01:07 PM
  #381
23r0k001's Avatar
Agreed...
Old Oct 10, 2007 | 01:10 PM
  #382
JohnBradley's Avatar
No MIVEC also has the advantage of altering cold idle emissions. It works all the time. I went through this last year and I think it has more to do with cold weather and the cold fueling modifiers in the ECU than MIVEC. Least thats my current operating theory.
Old Oct 10, 2007 | 01:45 PM
  #383
Jeff_Jeske's Avatar
^^^ Well my overall point is that it doesn't feel right. It feels like I'm trying to push the motor to do something it doesn't want to. I'm surprised no one else has noticed this.
Old Oct 10, 2007 | 03:44 PM
  #384
JKav's Avatar
The lack of ignition advance is likely the culprit making it sluggish. But why would alterations to the MIVEC table affect the ignition timing? This is odd...
Old Oct 28, 2007 | 06:01 PM
  #385
lemmonhead's Avatar
I made this map and works good.
Old Oct 30, 2007 | 09:36 PM
  #386
23r0k001's Avatar
what are your mods?
Old Nov 1, 2007 | 09:46 AM
  #387
gunzo's Avatar
Nothing better to do .. so did a load test .. this is the result ..
0 degrees
15 degrees
30 degrees
more or less agrees with the others that tested ..
Full advance up to around 6000
6000-7000rpms taper to 15
0 advance above 7500rpms
Old Nov 1, 2007 | 12:14 PM
  #388
fastrob691's Avatar
So have you combined all three and done another load test, and which is which one the test(30 is highest load at lowend, etc.) I am guessing thats it but clarify some please.
Old Nov 1, 2007 | 12:54 PM
  #389
lemmonhead's Avatar
so your saying you can have 30 in the maps all the way up to 6,000 RPM?
Old Nov 1, 2007 | 03:53 PM
  #390
gunzo's Avatar
didn't have that load test overlayed on this if that's what you're asking .. but yes, overall that was what I had .. combined the 3 and use the result ..
Yes .. that's what my car likes .. and it seems consistent with what the others have .. except for exactly when the cams should start retarding
