MIVEC tuning
Old Jan 24, 2009 | 09:52 AM
  #526
mrfred's Avatar
The biggest factor in MIVEC tuning at high load is the backpressure produced by the turbo. As back pressure goes up, overlap (high MIVEC values) become less effective or even detrimental. The stock turbo is a good example because people push it well beyond its optimum operating envelope. As load passes 240 and rpms go up (especially rpms), back pressure gets really high on the stock turbo, and best power is produced by reduced MIVEC values.
Old Jan 24, 2009 | 04:56 PM
  #527
gunzo's Avatar
Pretty much what I've seen on the X
Wanna talk about the exhaust mivec then ??
Old Feb 21, 2009 | 09:12 AM
  #528
cij911's Avatar
Would John / MRFred / NJ / Shameless / others, please repost you current MIVEC setups (it has been quite a while and I imagine things have changed )....
For a stock turbo being pushed hard on Methanol and 91, should the high load MIVEC values be 0 for 6000 rpm + ? Thanks
Old Feb 21, 2009 | 08:43 PM
  #529
mrfred's Avatar
Here is my current "work-in progress" MIVEC map. I'm running 26 psi at 3300 rpm, tapering to 25 psi at 5000 rpm, and then crossing 22.5 psi at 6000 rpm and 20 psi at 7000 rpm. It got me 10 whp over the MIVEC map below it. With some more more tuning, perhaps I can get another 5 whp.
"work in progress"
old map
Attached Thumbnails MIVEC tuning-mivec-high-boost-winter-2008.gif   MIVEC tuning-mivec-high-boost-fall-2008.gif
Old Feb 21, 2009 | 11:51 PM
  #530
inco9nito99's Avatar
Wonder how much normal pump gas maps would be affected by using the same methods of reduction.
Old Feb 22, 2009 | 06:17 AM
  #531
recompile's Avatar
This is the MIVEC map I used on the dyno below (boost is plotted). Evo Green, 30psi tapering to 26psi. 407whp, 375lb-ft with stock cams.
Attached Thumbnails MIVEC tuning-evogreen_75-_meth_10.06.08.png   MIVEC tuning-mivec.png
Old Feb 22, 2009 | 07:22 AM
  #532
cij911's Avatar
MrFred / Recompile -- Thanks for the updates!
MrFred / others -- So it appears that advancing cam timing helps ramp boost and that folks have been using 28.8 or 30 as the peak. What I don't understand is why in the 160+ loads you pulled the advance back to 22.8 vs 28.8? Was there too much back-pressure in those areas and reducing to 22.8 helped? If so, how did you determine (testing wise) that you had a problem and then how did you determine a value of 22.8 fixed the problem? (Sorry I am just trying to learn a bit.)
Thanks a lot!
Old Feb 22, 2009 | 07:27 AM
  #533
lacrosseks29's Avatar
it would probley make a good chuck less of power
Old Feb 22, 2009 | 08:46 AM
  #534
mrfred's Avatar
Thanks a lot!
As the exhaust pressure that drives the turbo rises, it can become higher than the inlet charge pressure (boost level on your boost gauge), and cam overlap causes the inlet charge flow to either stop or reverse. This tends to happen at high boost (high load) and high flow (high rpm) where the stock turbo is way out of its efficiency range. I think CH3CH3 posted some nice results on back pressure vs boost pressure measurements showing that its easily possible for the back pressure to surpass the boost pressure. The issue is exacerbated by any restrictions in the exhaust flow after the turbo, e.g. an HFC.
Once the boost starts getting pushed to its limit for the stock turbo, adding MIVEC only causes power loss rather than power gain. Less MIVEC gives less overlap and more power.
EDIT: I think I mentioned in my original post that the upper map is a work-in-progress. Its probably still a ways away from optimum.
Old Feb 22, 2009 | 12:12 PM
  #535
cij911's Avatar
Very informative, thank you.
Old Mar 17, 2009 | 01:54 PM
  #536
mike cy's Avatar
guys i need help on my evo9 . im going for tuning tommorow and i need help ajusting my exaust cam pulley. the cams i have are brian crower 272. has enyone ever put the correct decrease on the exaust pulley?
Old Mar 17, 2009 | 02:11 PM
  #537
GST Motorsports's Avatar
yes take the brian crower cams out and put others in. They are crap on the 9's.
Old Mar 27, 2009 | 01:46 PM
  #538
EE's Avatar
EE
"work in progress"
old map
Was the increase in power due to more airflow (at same boost pressure) or the new mivec map allowed you to run more timing at the same load??
Tks
PS: any updates on the map ?
Old Apr 8, 2009 | 03:13 PM
  #539
lan_evo_mr9's Avatar
This is basically MrFred's map with some tweaks. After thinking about the back pressure of the stock turbo that was discussed, I thought maybe try lowering it even more as the Rpm's go up. This map has helped immensely with boost taper (using a MBC). I now have my boost set to 26 psi and it only falls to 24 by 7K. Since I started running E85, all I wanted to do was crank the boost. I realized that may not be the best situation for the stock turbo. I was running really high boost, but with excessive taper and it was kinda dead up top. After lowering the boost, raising timing, leaning fuel, and MIVEC changes, the car has never been stronger.
Old Apr 8, 2009 | 03:23 PM
  #540
recompile's Avatar
It's not really possible to hold 24psi @ 7000RPM on the stock turbo. 20-21 if you're lucky, but more likely is 18-19.
Are you going by a visual check of your boost gauge? Unfortunately that's not good enough. Logging via a 3 BAR MAP sensor will reveal the bad news to you.
