MIVEC tuning
Old Jan 11, 2010 | 06:54 PM
  #676
JohnBradley's Avatar
Originally Posted by Danieln
Seems correct but I always get 72 value when I try to log mivec.
Where is the mistake?
Request ID in Evoscan looks like this
Hmmm, checked it versus mine and it is exact. Not sure but I would have to presume something in the EDM rom is not the same as the US as you had pointed too earlier.
Old Jan 12, 2010 | 01:25 AM
  #677
Danieln's Avatar
Hi JB,
I do not run a edm map
I test this a JDM map
Old Dec 22, 2010 | 02:54 AM
  #678
nonschlont's Avatar
Couple Q's.
1. Im still on the stock sticks, but have a larger turbo... From my understanding, theres really no gains on the stock turbo w/ advanced Mivec in the 6500+ region, but would I benefit from advanced Mivec in the 6500+ region, w/ the larger turbo?
2. Considering the stock turbo hits peak tq @ 3500, and I was holding 28.8* mivec till 4500. Now w/ the new turbo, hitting @ ~ 4400, can I hold 28.8* mivec till 5500?
Thought Id ask first, since its been raining for days, and I cant get out there...
Been trying to diagnose why Im WAY down on power... And the shop that preformed the work, seemed to think it was on par... hitting 240 load.
Old Dec 22, 2010 | 12:18 PM
  #679
mrfred's Avatar
Any benefit from intake cam advance at high airflow is going to be dependent on the ratio of boost to back pressure in the exhuast manifold. When the turbo is in its high efficiency range, there should be value to running some intake cam advance.
Old Dec 23, 2010 | 01:26 PM
  #680
nonschlont's Avatar
ty for the response!
Old Dec 24, 2010 | 09:18 AM
  #681
Carloverx's Avatar
So an FP black, running in the low 30s (a psi it should be very happy with), would benefit from more advanced mivec settings than a stock 8 turbo for example?
Sorry for the newb question... but:
The general idea is more advanced if it's going to help pull air out of the cylinder? And so more advance for a better flowing spot in the RPM range?
Sorry if that question doesn't make sense, i'm still learning lol.
Thanks
Old Dec 24, 2010 | 10:29 AM
  #682
Depends on everything else done to the car and the one variable we cant do anything about, the stock head. Some are better than others and some are very much needing a port job. I find for the most part the MIVEC is more or less the same on stock cams independent of turbo and changes only based differing cams.
MIVEC is altering intake advance which affects overlap which affects cylinder scavenging. We are controlling cylinder pressure with it almost as much as we do with actual ignition timing.
aaron
Old Dec 27, 2010 | 02:31 AM
  #683
nonschlont's Avatar
Wouldnt mind some guidance/insight from the gurus, on my current work in progress. Unfortunately not doin any more pulls till I get to the shop this week/weekend, and get the car running right again, but was running this w/
25psi, 4* @ peak and 25psi and 10* up top w/ under 3 counts of knock.
BBK-B / stock motor / stock cams, 100 cell HFC, 65mm TB w/ inlet port match,
76mm DP, exhaust, 3.5" cooler, full intake kit, FP, 1000cc Inj., o2 housing (recirc.)
Im wondering if its too aggressive early on, causing overlap, and not enough up top?
Old Dec 27, 2010 | 06:58 AM
  #684
SWOLN's Avatar
Not a guru persay, but it looks like you could adjust the spool up and the top end has alittle too much overlap. Aaron could offer more info than I though.
Old Dec 27, 2010 | 07:18 AM
  #685
vmrevo9's Avatar
Veteran: Air Force
Which version of evoscan logs MIVEC? I have 2.6 and I do not see the option.
Old Dec 27, 2010 | 11:26 AM
  #686
raasfaas's Avatar
I'm not sure if it comes setup in 2.6 but this is the line that you need to add to your data.xml
<DataListItem DataLog="N" Color="" Display="MIVEC" LogReference="MIVEC" RequestID="43" RequestID2="46" Eval="72-(0.6*x/32)" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="33" ChartMin="0" ChartMax="33" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
I use ID's 43 and 46...and make sure that in ecuflash you have the right addresses, 0x7650 and 0x7651 respectively.
Old Dec 27, 2010 | 12:54 PM
  #687
vmrevo9's Avatar
Veteran: Air Force
thanks for the code! just to make sure where do i get the address for MIVEC in ECUFlash? i looked at the .xml for my rom and i saw this
<table name="MIVEC Intake Advance" address="68bd">
<table name="Engine Load" address="7a64"/>
<table name="RPM" address="7a96"/>
</table>
<table name="MIVEC Intake Advance Min" address="293a"/>
<table name="MIVEC Intake Advance Max" address="293c"/>
<table name="MIVEC Max vs Coolant Temp" address="6a04">
<table name="Coolant Temp" address="6fde"/>
</table>
Old Dec 27, 2010 | 12:58 PM
  #688
raasfaas's Avatar
No the bit of code I gave you needs to go in your evoscan's data.xml
Then you open up your MUT table in ecuflash and make sure you have the addresses 7650 and 7651 at the locations you selected to log mivec at (in this instance its 43 and 46 for me)
Old Dec 27, 2010 | 01:02 PM
  #689
vmrevo9's Avatar
Veteran: Air Force
cool, the code was put into the Evoscan 2.6 data.xml
the bit of code i attached to the last message was from the rom.xml from ECUFlash, although i had to correct my post as i inserted the wrong code (in the post)
i'll check the mut table.
Old Dec 28, 2010 | 04:22 AM
  #690
mrfred's Avatar
Probably way too much MIVEC at high airflow rates. In my logging of both boost pressure and exhaust manifold pressure, I found that exhaust manifold pressure starts to exceed boost pressure by ~6000 rpm. No point in having any MIVEC advance when exhaust manifold pressure exceeds boost pressure. I'm on a BBK Full and E85, and you're on a BBK-B and pump gas, but I suspect that setting MIVEC to 0 at 6000 rpm and 220 load will give a bit better top end. Probably not much better, but a bit better.
