MIVEC tuning
Old Sep 26, 2009 | 10:27 AM
  #646
andrewzaragoza's Avatar
read the whole thread. there are a few good samples to start with. make sure you get the mivec map that was modified using stock cams.
Old Sep 26, 2009 | 03:09 PM
  #647
pug206's Avatar
Ok! I have read many pages but using a Spanish translator is not well understood ...
Old Sep 27, 2009 | 05:24 AM
  #648
wip's Avatar
wip
Stock cams/turbo, try the modified RS map as a starting point:
Old Sep 27, 2009 | 08:52 AM
  #649
pug206's Avatar
Thank you! I will do
A greeting!
Old Oct 2, 2009 | 11:20 AM
  #650
Armanc1's Avatar
Could anybody be kind enough and point me how do I actually log MIVEC? Many thanks!
Old Oct 12, 2009 | 09:46 PM
  #651
L@Ncer06's Avatar
If i use the rs map is it safe to leave my ignition and A/F map stock?
Old Oct 13, 2009 | 09:35 AM
  #652
jmcmill3's Avatar
yes, not a bad idea to log knock and afr's just in case
Old Oct 13, 2009 | 09:51 AM
  #653
JohnBradley's Avatar
You need to change 2 requests in your MUT table. Personally I used 40 and 41, then change the values to 0x7650 and 0x7651 respectively. I listed the formula above for EvoScan. The only thing that you'll have to do is set it up in EvoScan as far as the requests, formula, and units used.
Old Oct 13, 2009 | 04:04 PM
  #654
fryedchikin's Avatar
Yes, but you wont gain much. Fuel and Timing is where most power can be made.
Old Oct 13, 2009 | 04:08 PM
  #655
GST Motorsports's Avatar
Don't be so quick to make that statement.
https://www.evolutionm.net/forums/ev...advantage.html
Old Oct 13, 2009 | 04:15 PM
  #656
RinJuice's Avatar
are you sure this RS map will work for an EMD evo IX?
Old Oct 13, 2009 | 06:51 PM
  #657
yeah they are the same cams.
Old Oct 13, 2009 | 08:53 PM
  #658
L@Ncer06's Avatar
Mivec advantage?
So on that evo x were the afr's and timming left stock and will the same or around the same power be made with the evo IX?
Old Oct 26, 2009 | 06:40 PM
  #659
Originally Posted by JohnBradley
The values are 0x7650 and 0x7651. I think I am going to modify my rocker stopper in my MIVEC gear to get some more range out of it with the tall deck '64 I am doing. I will try to estimate 3.5* and see what we come up with.
Okay kids, here is the deal. I posted the how-to but I am gonna say it once and only once do it at your own peril. If you cant be bothered to do the math to figure out how to make it all work, the programming to actually make it do something, or the work of altering it, YOU ARE ON YOUR OWN. I will not answer any questions about this nor do I expect anyone else to...
...and I put a disclaimer in this as well:
https://www.evolutionm.net/forums/en...ml#post7654298
Old Oct 27, 2009 | 07:17 PM
  #660
rolly1818's Avatar
Registered User
hmm just saw this....gonna take a read thanks again
