ECU Swap & Immobiliser Code Issues
Old Jan 7, 2009 | 06:14 AM
rolly1818's Avatar
Registered User
Question ECU Swap & Immobiliser Code Issues
this one is goona be long!
i have a JDM 2006 Evo IX GSR.
when i got the car i used a Evo IX GT ECU (long story) rom id - 89980000
however, because of the very few GTs a definition file was written for this rom. this caused all kinda probelms in the maps. e.g. no rev limit and random timing values
as a result, i swapped ECUs to a EVO IX JDM GSR ECU in order to get the car up and running properly. rom id - 89280002.
well the car did not start (as expected) because of the different immobiliser codes. as a result i flashed my old GT rom back onto the new ECU (8998000).
the car is starting no probelsm but i am back to getting the same problems of no rev limit, etc.
can anyone assist in changing the immo codes for me. i tried it but the car still wont start with the 89280002 rom!
i just want my stock map so i can start tuning.
Thanks in advance
Old Jan 7, 2009 | 10:27 AM
rolly1818's Avatar
Registered User
update:
just flashed my 89280002 rom back to the car with immobiliser codes - 8001 and FFFF
still did not start.
bump for help!
if you need my roms, just let me know i will email them!
Old Jan 7, 2009 | 10:29 AM
RoadSpike's Avatar
Originally Posted by rolly1818
update:
bump for help!
Why oh god do people think that putting FFFF in the immobilizer code it will magically disable it?
You have to edit the ECU periphery and disable bit 3..
Old Jan 7, 2009 | 10:31 AM
rolly1818's Avatar
Registered User
to be honest..sounds like greek to me...
BTW thanks for the help on the 3 port BCS, i am installing this weekend!
Old Jan 7, 2009 | 10:37 AM
RoadSpike's Avatar
You know how to edit your rom.xml file to add a table?
<table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Stock should be 56DA
Change to 56D2
Old Jan 7, 2009 | 10:41 AM
siceclipse's Avatar
wat?
rolly1818's Avatar
Registered User
now its sounds like chinese....
i have no clue how to change xml files. so ur saying, go into 89280002 xml file and just add in:
then change a value from 56DA to 56D2?
what will be the outcome?
my tuner made the GT rom (did not turn out too well)
Old Jan 7, 2009 | 10:46 AM
RoadSpike's Avatar
Yes add the table definition into the xml file.
What the code does is disables the immobilizer unit so ANY key can start the car. If thats really your issue the code will fix it.
btw enter the value in with a leading 0x so
0x56D2
Old Jan 7, 2009 | 10:52 AM
rolly1818's Avatar
Registered User
simple enough, one last question...where do i add the table. that is where do i copy and paste the text into the xml file???
i have never done this b4.
Old Jan 7, 2009 | 11:21 AM
RoadSpike's Avatar
Just add it at the very bottom but before it says "</rom>" it needs to be above that block.
Old Jan 7, 2009 | 12:33 PM
rolly1818's Avatar
Registered User
just tried not starting!
i changed the immobiliser code to "56D2" as u asked as well.
i attached my xml file so u can have a look!
File Type: zip
Old Jan 7, 2009 | 01:23 PM
RoadSpike's Avatar
What?
Not changing the immobilizer code.
There should be a new spot under Misc named "(periphery 0)"
Change that value to 0x56d2
Old Jan 7, 2009 | 01:47 PM
xpro's Avatar
should you not be using 8857008 on ix jdm gsr ecu?
Old Jan 7, 2009 | 02:59 PM
rolly1818's Avatar
Registered User
just tried again, Thanks a million bro i owe u some
curious to know why????
Old Jan 7, 2009 | 03:58 PM
tephra's Avatar
no 899880002 is the correct romid for a GT
