Patch: Force OBD Inspection Pass (acamus, mrfred)
bump for help. I gotta get reinspected this week
Bump for some smart peoples help please
. Getting reinspected friday. Which values in which tables should i set to 0 and 1 to make it look stock instead of having everything set to 1
No, you should leave the A/C System, 2nd Air System, Heated Catalyst OFF also in the "available" so it will show "N/A" on the read out at emissions. Otherwise it will show READY and that will look real fishy.
Change EAFF to EAE5 and both tables will be the same, and setup like OEM. to change press = then enter 0xEAE5
One last question though on my stock map before changing any values for the monitor passed/failed table the heated catalyst has a one next to it. Why is that?
I don't know why yours was set that way but the heated catalyst should be set to 0. Once you have it all set and flashed back to your ecu, you can test it out by using a OBD reader as well. It's not necessary but I just do it as a 2nd verification that my changes went through correctly.
Thank you so much for posting this! It was the easiest thing in the world (once the video link was working again). PS, I did have to add that scaling to the Evo7base file as well, because I couldn't see the values for the available/pass tables.
Can someone post the answer to this or pm me as I am also experiencing the same problem on 9170008. Im using v 1.29 due to the cable that is available to me. I notice this is not an issue on 1.4
