FP RED dyno results thread
Old Feb 15, 2013 | 04:10 PM
  #331
tscompusa's Avatar
Originally Posted by kevin8086
Ok so I found my throttle body seals r leaking. How bad is that leak with regards to power? Also my stock 9 bov opens at 27ish psi so that why anything over 27 wasn't making power. Still not sure why I get knock at 25 psi and 1-2* timing at peak.
Boost leaks hurt power a lot. what happens is, the turbo has to work harder then it normally should to keep pressure in the system, so in turn you're overworking the turbo and making your entire setup less efficient and creating a lot more heat.
The knock off FMIC can be killing the power also. I've seen 50whp~ gains from just FMIC swaps on 93octane. the FMIC is very important with 93octane to make good power.
Old Feb 15, 2013 | 04:13 PM
  #332
tscompusa's Avatar
Oh could it be my RC1000 injectors? I did get them used. If one was not spraying correctly would that cause low timing due to possible detonation?
yes, but i really doubt that is the issue. but if one injector is not spraying as it should be that cylinder can run leaner/hotter then the rest and cause issues. i would send them to FIC and get them flow tested to be safe. its probably not your issue, but im sure they could use a clean up.
Old Feb 15, 2013 | 10:21 PM
  #333
kevin8086's Avatar
Thank you for all your input and response. Ill change out the throttle body seals and start looking for a better fmic. Would the stock fmic be better then the 3.5" ams knock off? The inlet temps and pipes are very cool in the far side of the fmic and pipe but not sure how good the flow is through it and I'm assuming that's where the problem would be.
Old Feb 15, 2013 | 11:42 PM
  #334
tscompusa's Avatar
no. im sure your knock off is more effective then the small stock fmic, unless the aftermarket one is clogged up.
throttle body shaft seals leaking is a pretty big leak, you will gain spool and more power.
no problem at all. if you need any parts or assistance feel free to pm me.
Old Feb 16, 2013 | 06:57 AM
  #335
kevin8086's Avatar
I definitely will. Ill sell this intercooler and my stock intercooler and should be able to pick up a proven fmic from you. Thank you for your help
Old Feb 16, 2013 | 08:41 AM
  #336
forzaM's Avatar
I have some numbers with the new fp red BB. At the moment we are able to get around 460 whp uncorrected, but we have problems at high revs, the power drops around 6000 rpm, see the progression:
460 whp uncorrected (black line), at 4000 rpm around 220whp:
We work on improving low numbers, see the difference....440 whp uncorrected (black line), and at 4000 rpm 310 whp:
Also see the temperature, around 93 fahrenheit.
Now we take out the head and try to improve it, also new exhaust and exhaust manifold, s90 tb, we will see....
Old Feb 18, 2013 | 12:48 PM
  #337
kevin8086's Avatar
Sooooo great news. I replaced my HFC with a resonated test pipe and the car came alive. Looks like the HFC was bad
Old Feb 19, 2013 | 03:04 AM
  #338
tscompusa's Avatar
good find. glad i could help
Old Feb 19, 2013 | 08:21 AM
  #339
High_PSI's Avatar
HUGE power loss here, HUGE, I had mine leaking and went from 340 to 367 stock turbo.
Get them fixed ASAP and also get a new BOV that holds man, what are you doing here?
Old Feb 19, 2013 | 11:19 AM
  #340
xtruemassacre's Avatar
Old Dec 17, 2014 | 10:12 AM
  #341
EvoIX89's Avatar
My setup:
06 evo 9
Curt Brown 2.0 short Block
Bored .020 over
Manley 9.0-1 pistons
Turbo Tuff Rods
Curt Brown Ported Evo 9 head
Supertech valves, GSC valve train
GSC S2 Cams
Curt Brown Ported Intake Mani with 65mm TB
GT Spec tubular exhaust manifold
All ETS 2.5 intercooler piping
ETS 3.5 inch intercooler
Tial BOV
Ported FP Red DBB w/18 PSI WGA
HKS 3 inch turbo back exhaust, no cat
Works cast 02 housing
Car was tuned by Jason @ TPG Tuning on their Mustang Dyno
32 PSI Made 467whp 419wtq on 93 octane
Dyno pulls were done in 3rd gear on a 6-speed trans
Attached Thumbnails FP RED dyno results thread-evoix89-194803-albums-garage-gg-evo-9-11423-picture-fp-red-dyno-results-43458.jpg
Old Dec 18, 2014 | 09:01 AM
  #342
Abacus's Avatar
Here are my results.
Real Street performance tune
88K stock engine/cams/coils
FP Red DBB
FP manifold
ID1300's
Walbro 450
Tomei full Exhaust
RSP built trans with 4.11 and evo 8 gearing
RSP 4" intake tube into a Kansai Service Carbon Fiber intake box
ETS 3.5" intercooler*
AMS pan
Pump E85
The Red does require porting of the wastegate entry. It used to make 26psi above 5000 and now that its ported it makes 22-23. The 450 pump is out of fuel at 500whp for me on the stock wiring. I'm going to rewire it or use a Boost a pump if I decide to go higher. I normally run the car at 440-460 around town.
Old Dec 18, 2014 | 10:34 PM
  #343
mrfred's Avatar
great powerband. i suspect the 4.11 fd is helping a bit with the fairly early boost threshold. also very impressive if its 500 whp at 23 psi.
Old Dec 19, 2014 | 10:56 AM
  #344
Abacus's Avatar
Thanks! It does spool well, it makes 20psi by 3600rpm in 3rd on the dyno/street. It makes about around 10whp per pound of boost after 23psi. The 500whp run was at 28-29 after 6000rpm.
23=430
24=440
25=450
26=460
27=470
28=480+
29=490/500
Old Dec 19, 2014 | 12:56 PM
  #345
mrfred's Avatar
Ok that makes much more sense.
