Highest HP 4g63 engine (from 2007)
Old Dec 20, 2011 | 10:48 AM
  #1036
binky's Avatar
That's some extensive port work. Talk about removing a ton of material.
After opening the ports on the head that much are there any drawbacks besides spool up? Can that cause structural issues with the head?
I'm looking forward to seeing what your custom head looks like. Let's see some pics!
-Bink
Old Dec 20, 2011 | 04:17 PM
  #1037
R/TErnie's Avatar
besides the portwork Sypros, do you have any plans to improve the stiffness of the cylinder head?
Old Dec 20, 2011 | 04:28 PM
  #1038
gasolinebaptism's Avatar
I guess I'm not seeing the point as to why he needs to stiffen the head.
He'll have the best studs made to hold each cylinder secure, it's likely o-ringed, and he has copper beryllium seats.
Old Dec 20, 2011 | 04:48 PM
  #1039
turbopineapple's Avatar
Very nice work Spyros.....
By manipulating the floor and ceiling port velocity can be increased. Low end airflow speed will be affected but may not be as bad as you would think.
mikey
Old Dec 20, 2011 | 05:45 PM
  #1040
Drifting Away's Avatar
thats some nice port work.
Old Dec 20, 2011 | 07:06 PM
  #1041
Tony the Tiger's Avatar
Raised ports always worked well for the Honda community.. I can see this being a good way to make these Evo cylinder heads flow well past 9K RPM without requiring crazy retarded big cams.
I bet there's going to be a lost of spool, but the RPM game is always losing a bit but gaining lots. Losing 500RPM of spool but earning 1000-1500RPM worth of redline + response easily makes up for it, and then have proper gearing to match.
Old Dec 21, 2011 | 07:22 AM
  #1042
CBRD's Avatar
we have been trying to massage the ports a little on the stock head to change the angle- but nothing this extreme-
probably would be easier to just have spyros send us one- but then we need to build a custom intake manifold- oh well..... thats been on the drawing board anyway LOL!
killer stuff- cant wait to do more with it
cb
Old Dec 21, 2011 | 07:24 AM
  #1043
khmerpimpin's Avatar
cb
Time for you guys to add to your order
Old Dec 21, 2011 | 08:48 AM
  #1044
R/TErnie's Avatar
You can have the best head studs and the best o-rings, but if you're putting them in a wet noodle.... it'll be pretty hard for it to hold in a fart let alone 700whp worth of cylinder pressure.
As you increase the cylinder pressure you need the cylinder head to be more rigid as well to help hold the gasket.
Old Dec 21, 2011 | 09:25 AM
  #1045
true's Avatar
Can I hear a BILLET HEAD! Whop whop
Old Dec 21, 2011 | 09:39 AM
  #1046
R/TErnie's Avatar
A properly designed cast one would suffice, but the forethought needs to be there to make it happen.
Old Dec 21, 2011 | 10:16 AM
  #1047
Extreme Tuners's Avatar
So I am back again.
It’s the unofficial crank test, its time some companies get serius and don’t promise HP and Rpms just because they think nobody can push them at the limit.
We test them on the Dyno from 1000- 1500hp, on the balancer machine at 12000rpms. To be fair we use Combustion / Pressure analyzer to calculate the actual compression and combustion pressure in the cylinder as the strokes was diffent so as the piston at BTDC and TDC. Same pistons speed but diferent weight piston rod combos makes our test 5% inaccurate.
We knew from the start what would be as we wanted to test all the "off the shelf" 800-4000$ cost cranks. We test 12 cranks. Not survival as we think from the start.
We will show u the results but not the brand for eatch crank.
Spyros
Old Dec 21, 2011 | 10:33 AM
  #1048
Teal2nnr's Avatar
^^^ nice, looking forward to the info....although without knowing the companies that make the cranks, kind of hard to make a decision on which on to get, or stay away from....but its understandable why you'd keep it confidential.
Old Dec 21, 2011 | 10:57 AM
  #1049
binky's Avatar
Not sure why you would keep this info confidential. I mean I guess it gives you an a edge as a company, but that would have been like AMS keeping the cam test confidential.
Too bad this test won't educate/benefit the community. Seems if you are going through all the trouble, time and money to test out cranks, you might as well share the info.
-Bink
Old Dec 21, 2011 | 11:14 AM
  #1050
-Bink
Agreed, maybe in due time.. (he doesn't want the shops stateside to copy)
