Highest HP 4g63 engine (from 2007)
Old Jan 23, 2012 | 01:48 PM
  #1276
R/TErnie's Avatar
Originally Posted by Erland ***
I will try to ask you once more about why you want to use bigger exhaust than intake valves in the head. Also I want to ask you if you have watched the videos of the 1300 hp Volvo that I posted that ran 6.85-322.
There are giant problems to keep the block together at that power level for drag racing but you seem to have no problems whatsoever to keep the engine together at 1500+ hp for street driving? How come?
Erland
He produces less or equal cylinder pressure than you do... he just does it at a higher rpm.
Old Jan 23, 2012 | 02:34 PM
  #1277
Elevent's Avatar
Hi Spyros,
Do you make any changes to the bearing sections of the Turbos? Any other changes than wheel upgrades?
What kind of improvements should we expect from your 11 blade wheel design compared to genuine GTX3582? Power? Spool?
Thanks
Old Jan 23, 2012 | 03:12 PM
  #1278
GraphiteEvo9's Avatar
Originally Posted by Elevent
Hi Spyros,
Thanks
He posted some info previously
Originally Posted by Extreme Tuners
Our 11blade 64mm outflows any T3 67mm on the market and spool 25-300rpms sooner. Our 67mm 11blade is close to 150-200hp more than the competition.
I will make next post for these t3 frame turbos.
Some guys here have already order some units.
Options with billet catridge, triple ballbearing, titanium compressor wheels, GammaTi turbine wheel, also available in aditional costs.
Spyros
Old Jan 23, 2012 | 08:23 PM
  #1279
Erland Cox's Avatar
Why does his car look so much less powerful then?
Erland
Old Jan 23, 2012 | 09:19 PM
  #1280
R/TErnie's Avatar
Why does his car look so much less powerful then then?
Erland
Probably because it's slower? F=ma
Old Jan 23, 2012 | 09:55 PM
  #1281
Erland Cox's Avatar
F = M X A
A = F / M
For F I substitute hp
Volvo 1300 / 2300 = 0.556
Mitsu 1456 / 3300 = 0.441
.556/ .441 = 1.26
1.26 X 6.85 = 8.63
With that power the Mitsu should be able to run in the 8:s.
Was it tested to 9.12 seconds on a drag strip with timing?
Erland
Old Jan 24, 2012 | 01:12 AM
  #1282
Extreme Tuners's Avatar
Erland
How u judge that? Do u know times from the car?
Old Jan 24, 2012 | 01:53 AM
  #1283
F = M X A
A = F / M
.556/ .441 = 1.26
1.26 X 6.85 = 8.63
Erland
Its actually a 8.5sec car full interior. Read carefull my previus posts before write.
I dont want to repeat my self.
The car never start from standing so the 9.1 was the time 1/4 of haybusa 505whp turbo. We wanted to see acceleration and compare to busa turbo.
I remind u that its full street car as u might know with full stock interior with driver and co driver and slight uphill road. The total weight on the test was 3580lbs.
If u like numbers then calculate the real world numbers same road as we did the test.
Our evo ix 3580 weight 2ltr 1456hp (at the tests had ~1380hp)
The bike of the test was Haybusa 1300cc 680lbs weight Gt35 505whp (550hp crank) with excelent driver.
Real world times not sugestions shows:
Evo 1400hp
From 100kmh to cover 100meters had 2.52sec
From 100kmh to cover 200meters had 4.34sec
From 100kmh to cover 300meters had 5.89sec
Haybusa turbo 550hp
From 100kmh to cover 100meters had 2.54sec
From 100kmh to cover 200meters had 4.29sec
From 100kmh to cover 300meters had 5.78sec
The bike was 0.11sec faster than this evo. The bike had:
11.84sec to 0-300km/h.
0-1000m 16.23sec with 326.16 km/h
So if the car is so close to this bike u still think that this car is slow?
Also this car have 300hp more as was only 28-30psi at this test.
With just math u try to prove that the car is slow make it reverse to prove u that math are not the only way to calculate but time. Real world is few lines above.
Busa 550hp / 310kgr = 1.77 (the bike have 1.77 hp to move 1 kgr)
As the evo was too close to busa we take the ratio of the bike
Evo (?) hp / 1630kgr = 1.77 x 1630kgr = 2.885hp was the evo at these test with cold math.
Please read carefully next time. Real world is the time not math. Read and compare again Bike and car times.
Spyros
Old Jan 24, 2012 | 09:23 AM
  #1284
juanmedina's Avatar
so what was the 60-130mph?
Old Jan 24, 2012 | 09:37 AM
  #1285
gasolinebaptism's Avatar
I'm with juan.. We believe your car MOVES Spyros.
We're just hoping you broke the record.
Old Jan 24, 2012 | 09:44 AM
  #1286
Broham's Avatar
If this car goes 8.5 being "fat" Then what kind of time is possible at higher boost with some reasonable weight deduction? Like only 1 driver and maybe some lighter seats. 7.99??
Old Jan 24, 2012 | 10:11 AM
  #1287
kouzman's Avatar
I think the 8.5 sec is an estimate. As far as I know there is no Evo, Subaru, Ford, Lancia faster than 8.8 sec in Greece yet. Not an estimate but actual timed pass at a strip.
Old Jan 24, 2012 | 04:36 PM
  #1288
Erland Cox's Avatar
Evo 1400hp
Haybusa turbo 550hp
Spyros
And the 2300lbs Volvo does 0 to 322 km/h in 6.85 seconds in the real world.
Timed at a drag strip and shown in a video.
Erland
Old Jan 24, 2012 | 04:52 PM
  #1289
kouzman's Avatar
Erland
These videos make me wanna buy a Volvo!!! Amazing stuff!!!
Old Jan 24, 2012 | 07:00 PM
  #1290
JohnBradley's Avatar
Street Volvos are pretty cool. This one runs all Mitsu Electronics, ECMlink V3, the same cam profile I run in my Evo, and one I tuned as well-
http://www.youtube.com/watch?v=aOu5L_iHdzg
500whp at 26psi on pumpgas...very sleeper.
