Highest HP 4g63 engine (from 2007)
Street Volvos are pretty cool. This one runs all Mitsu Electronics, ECMlink V3, the same cam profile I run in my Evo, and one I tuned as well-
http://www.youtube.com/watch?v=aOu5L_iHdzg
500whp at 26psi on pumpgas...very sleeper.
This is a B23 4 cylinder with the 16v NA head added (stock is 8v 2.3). We never pushed the stock block, Nathan (the owner and fabricator of the turbo kit and intake) built the motor when it came time for the big motor. It is now a 2.5L stroker motor (96x88 I believe) with 158mm rods. I have tuned a T5R wagon or 2 that made 300whp stock motor with larger turbo and injectors.
the maximum possible so far with pump gas is 550 whp with stock frames in USA for the most part with fp black and that is with a lot of boost (32+psi) manifold/port head etc. Many in the community who wants to get 600whp without selling everything and going to t3 unit and using pump gas easily since e85 fuel is not easy for everybody without going t3.
When someone gets tired of stock frame they go to t3 for more power because stock frame is not easy to get to 600 hp without a loooot of work or a lot of e85 and hi boost. If you have turbo solutions for high hp turbo and stock frame over 600 hp 93 pump please share.
The other power group is the fast spool community who just want very good spool and more power for track use and street driving.
that is the restriction.
I believe spyros has done some modification to cure that problem. If not, i guess t3 is king. But if he hadn't i don't believe he would've achieved 840whp.
As comparison from an fpblack we had 540whp stock fuel and 580whp with race fuel at 38psi to a stage 1 engine 11,2cr 2ltr. There was the limit of the black to our dyno.
As i write to previous post we use from above this garrett ATP turbine housing.
Erland
Ti compressor wheel would be nice!
