Buschur Racing's first 2.4 L engine build, results inside.
The car was put back on the dyno today. Numbers are basically the same with pure 93 octane in the car. I ran the car out to 8,000 rpm, power as can be seen in the first post was starting to fall by 7500 rpm and that trend continued on and doesn't make for an impressive looking dyno sheet.
This car was knock prone on the original 2 liter. The engine did end up spinning a rod bearing BUT I can usually pick up on that type of noise and even with listening to the engine a few times during the orignal tuning session I never heard anything.
The knock activity is still there and it's aggravating. Considerable time was spent today and it's as sorted as I can get it. 25 psi seems to be about the peak boost for 93 octane.
There are many things that can cause knock and I'd love to go into great detail here about my thoughts on this but it's not for here. Post are taken down and it pisses me off, so I'll leave the better tech for elsewhere.
Rogue, I'll try to give you a call tomorrow.
Time to try meth or e85?
At least a meth kit is easy to do an cheaper then going with e85 would be a quick test to see what the engine can do.
Really liking the numbers you are putting out BTW this thing can handle so much more can't wait to see what you get it up to.
rogue, i can't wait to see this thing run man. it pulled strong on the 2.0 so im sure this 2.4 will be impressive on the street. I would definitely like to see you upgrade to a black....but you know that. stop by when u get the car back.
444/433! hell, im hoping my car puts down those kind of numbers on a dynojet lol
the 9.5:1 is probably the biggest limiting factor for boost on 93. On e85, meth, or anything 100+, I'm sure that the results will be night and day, well, more so then "usual". Nice build.
do u think my VIII and X can do 30psi pump gas? would i still achieved same power as e85 with 30psi? iam willing to retune to pump gas this summer.
I guess they do not understand the point of a tune?
I want to see some vids of it though.
Its got more in her, get the knocks down, its awesome to see the the hp and the torque are pretty much matched.
Wet and salt covered roads ftl tho.. lol
First gear RIPS the tires off from 4-5500. Second isnt AS bad.. lol Third feels light on its feet even!
I know their ****tier... tires Kuhmo AST 245/xx/17's.. But still...
