CBRD new BBKB results
Gentlemen,
we are doing testing with the turbo and things are looking good, part of the hold up is having the proper oil lines produced in the volume we need, and with the right style fittings. I should have that resolved this week,
Right now our BBK Full price is 1740 shipped with porting...
The BBk-B (comes with a port) is looking like it will still be 1840.00 shipped with the oil line and uprgaded bearings.....
we are restructuring the pricing program for used cores... since we have the following scenarios:
Stock evo IX turbo converted to BBK-B
BBK lite compressor only converted to BBK-B
BBK full converted to BBK-B
thanks again for being patient.. we have a lot going on right now (evo X tial housing development among other things)... and our fabrication picking up more projects, so I'm trying to move forward without rushing ANYTHING.
As for the comment about us being "too honest" about the issues.... We like putting the information out there. It is better to address an issue head on and make people aware, than to have to reply to "rumors" of problems during development after the product is released.
Sincerely
CB
Sincerely
CB
Also, I assume that you are speaking in generalities, but you, in a BBKB thread, are saying these turbos do surge without the cover. People reading will now assume (and already have assumed) that you are speaking about the BBKB when in reality you have not tested the turbo yourself to see whether or not it surges, which by the way, it doesn't.
Don't mean to come off in a hostile manner, but you are making a bold claim.
vrmevo9, I agree totally on the oil line situation. I think some people forget this thing is still in PRE-PRODUCTION and has not been officially released. So in a way you almost feel like CBRD is too honest and could've kept this all hush-hush. I am glad they are transparent. My concern now is with the stock compressor housing. Or is it? I know they know their stuff and really doubt they would sell a surge prone product but it would be nice to get some info on the technicalities of how they achieve this. We know how FP does it. But again, pre-production so maybe I am jumping the gun here...
Think about it this way, if they came out with the same product in the end, would you rather have them get it right by chance the first time or would you rather have them understand why things need to be configured in a certain way?
I can almost taste it, getting close...its delicious! Jk, really looking forward to this turbo seeks as though it will have the top end similar to a red while only giving up a few hundred rpms of spool compared to the full. Only time will tell but this seems to be on track for the best overall pump gas turbo imo, we will see!
I also can appreciate their transparency. I think that is the direction that we are heading as a whole. Some people are dissuaded to know that CBRD isn't a magic black box that pushes out perfect products. What they need to realize is that when you create and innovate, you will run into disruptions. Failure leads to success.
I'd like to see a video of a 4th gear pull started at 2k with the wastegate preloaded to hell running c16 @ 30+ psi. If you can do that without surging I would consider its safe to say that the turbo does not surge. I had that experience with my 64mm Red... which I would say is going to be similar to this turbocharger. I had surge issues in 5th gear getting into boost passing people on the freeway with my Red.
My comment was not to hate on CBRD... it was to state that IMO this BBK-B will be released with a new oil feed line and an anti-surge cover. I find it difficult to swallow that this turbo will not have surge issues, but I'm open to being proven wrong.
-Eric
Boltz.,
-Eric
-Eric
As a beta tester I can tell you that it does not surge. My testing has including many 3rd/4th gear sweeps starting as low as 2k rpm. Also had a W/G line pop off and it hit over 30. I was only on it for a half second but it didn't surge that brief moment either. To avoid popping the stock motor I avoid WOT at low rpm in 5th so I cannot comment on that at the moment, also haven't been on the highway since testing.
Edit: I can't promise it won't surge ever for anyone, but it looks good so far!
Boltz.,
-Eric
-Eric
For fun... set your turbo up with 0 preload...and tune your boost curve... then add 2 turns... and then 2 more...and then 2 more... until you're at the end of the rope for pre-load adjustment. This keeps the wastegate puck firmly pressed against the housing preventing premature venting of turbine pressure.
Go read up on how springs work. They linearly open with increasing force applied.... they're not digital.
Gentlemen,
Sincerely
CB
Sincerely
CB
