evo 9 with BBK Full @ 30psi on 93oct
Old Jun 7, 2011 | 07:17 PM
  #76
batty200's Avatar
I agree ecuboost is the best in terms of features and control and once it is thoroughly debugged I will use it and save the avcr for a car with a less awesome ecu. I do however like being able to control boost without changing maps so a standalone ebc is very desirable to me. I am also using a 4port with my avcr to try and get it to have max range of boost levels and control. Different strokes for different folks!
Old Jun 7, 2011 | 07:56 PM
  #77
howell's Avatar
that's some great numbers Tom. and congrats to the owner also.
Old Jun 7, 2011 | 08:59 PM
  #78
RazorLab's Avatar
Originally Posted by Tarmacisback69
400whp on a mustang : /
400whp has been even achieved on 91 oct on a very well setup Evo on a proper Mustang dyno.
Old Jun 7, 2011 | 09:33 PM
  #79
06MREvo's Avatar
I made over 400whp on CBRD's mustang dyno @ 26psi...stock block, 93 oct....
Old Jun 8, 2011 | 02:25 AM
  #80
tscompusa2's Avatar
Originally Posted by Aby@MIL.SPEC
Im not suggesting that your imagining this issue, but when other people experience just as good / if not better controlled boost results with an ebc over a mbc....makes 1 think that it maybe the indian & not the arrow.
I cant say i appreciate this comment to much..
let me explain something to you. you know the setting in v7 where it says WGDC=100% under this Load? I was hitting 536 load in my car and i set it to 350 load to hold the boost to 100% until 22psi. the car has a 25psi wga on it preloaded to 30psi..
so you would expect it to make it spool quicker right? since you're forcing it to hold 100% longer to get max spool.. well the higher i raised that number the worse the spool got. I ended up ending with it back about 270 load where it is making 15psi and that is where i got the best response. thats why i think something fishy is going on with the overall operation of this thing in the code. its simply not doing what you tell it to and boosted tuning explained it doesnt do this already 2 times now in this thread.
heres the settings i was using in my personal car;
**removed**
now are you gonna tell me its still the indian and not the arrow after what i said? or am i missing something here? should of brought the 100% wgdc in the map above to around 4k range? if it changes over to this table during the spool process then that could very well be a big possibility.. but does it is the question?
Originally Posted by batty200
Tscomp is NOT saying an MBC is better than a EBCS. He is saying ecuboost controlling the solenoid is not as good. The increase was on a solenoid with a different controller. AEM truboost is what is kicking the ECU's ***. This is why I have an AVC-R for now since it does rpm and gear based boost control.
Good Job Tom. I hope they figure out the ecuboost issue since I like all the features of ecu boost.
I am but im not, from experience on my car when i hooked up the mbc back on i gained lots of spool and more punch downlow... didnt notice anything different uptop though.
the ecu boost definitely craps all over the mbc as far technology goes and all its advanced features it has.. you can literally control the boost in the rpm's as you rev the car, its pretty crazy stuff.
Thanks for the kind words adam.. did you ever get a fmic? lol i still have the perrin here.
Originally Posted by 06MREvo
Tom, I must say, you are a remote tuning machine....So the owner went from a 3 port to the AEM true boost, turned it up another 1.5psi, and gained almost 50wtq?? Ridiculous....I am assuming you will be testing a Hallman Pro RX MBC with the stiff spring??
No matter what your car is making some great power man...You may loose a little down low with the S2s but the gains up top should be nice...
Thanks man lol. that comment made me laugh. Put some tokens in me and get an auto tune.
Yes we are testing with the new heavy spring
Originally Posted by Guerillah
The stock ecu boost control is vastly superior to any boost controller on the market for the following reasons: Map switching capability, knock control over boost, gear dependent boost curve, boost limit (fuel cut if overboosted).
Let's wait until this is fully figured out before we start to say ecu boost control is inferior to a MBC for spool up. Someone needs to put an oscilloscope on the boost solenoid and see what its really doing. If my car wasn't missing an intake manifold at the moment I would oblige.
I agree and not denying its advanced and has many good options. id love for someone to do that test.
to everyone else thanks.. more testing to follow soon stay tuned.
Old Jun 8, 2011 | 06:17 AM
  #81
05blue8's Avatar
I sent him my info yesterday but he never posted it...not sure why. All I got was a "the hallman killed it, I knew it would" response. I'm going to see if I can find both logs and post them up. I expect Tom to spend more time tweaking things on his car to make them the absolute best so when he's talking about tweaking load for max spool I'm pretty sure he hasn't done that for my personal car but I can't be sure. Give me a few and I'll post up the results that I got and I'll happily answer any questions re: does your ROM have this set, that set etc and look at it.
Here's the graph, the hallman actually peaked to 35.24 at 5450, the ecu boost peaked to 36.43 at 5990. I tried to keep them as close to identical as possible but obviously missed the boost a tad bit.
My hallman has the new "super spring" with the steel ball. I needed to hold more boost longer and the steel ball gave me the most bang for the buck to hold boost the longest. The ceramic was great but it gave up too much up top. I tested both ***** with the stiff spring, then both ***** with the super stiff spring (you have to call hallman and ask for this one, it hasn't been released yet).
Old Jun 8, 2011 | 07:22 AM
  #82
Aby@MIL.SPEC's Avatar
Originally Posted by tscompusa
I cant say i appreciate this comment to much...
I apologize
Old Jun 8, 2011 | 08:29 AM
  #83
blackenedwings's Avatar
We aren't still talking BBK Full on 93 octane right?
Old Jun 8, 2011 | 08:36 AM
  #84
05blue8's Avatar
Wouldn't the BBK owners be happy to see those numbers, haha.
No, we're talking about what the current topic is in this thread...ecu boost vs mbc and issues surrounding swapping back and forth. I'm posting this in here because that's the current topic of discussion and it is of benefit to everyone who is following it and wants to see the difference going from one to another regardless of turbo. My set-up is in my signature
Old Jun 8, 2011 | 08:45 AM
  #85
CBRD's Avatar
ok now that is interesting. because as you can see in this test here the spool wasnt really changed just the tq quite a bit due to more boost with the truboost..
but on my personal car that runs 9417**** v7 rom i had a way laggier spoolup. now if this car doesnt gain any spoolup when it puts a hallman on then i think you got something there.. so the 05+ actually have a better control in spoolup then the 03-04's ? and can you explain why this is changed in those roms and not the older ones?
basically roadspike said it trys to hold 100% then goes to 0% and constantly clicks back and forth from 100 to 0 and it prematurely cracks the flapper open at spoolup.
This cars using 88590715-v7
tom im confused by this statement-
you just said "you can see in this test here spool wasnt really changed just the tq quite a bit due to more boost with the truboost.."
You would expect more torque, as boost makes torque power....
what was the problem that you simply didnt just run more boost on the 3port since the torque was the same?
It wasnt an apples to apples comparison as you didnt run exact boost pressures on the same setup-
insight?
(I do appreciate the discussion from all sides)
cb
Old Jun 8, 2011 | 11:12 AM
  #86
Go_Lancer_Go's Avatar
Anyway to get the best of both worlds ??
Im wondering if i should get rid of my GS until this is resolved but I dont think I should b/c of 2 reasons
1. Gear Based Boost
2. If I ever do Meth, I need it for map switching.
Old Jun 8, 2011 | 12:52 PM
  #87
05blue8's Avatar
1. Gear Based Boost
That's what tscomp and roadspike are working on
Old Jun 8, 2011 | 12:55 PM
  #88
tscompusa2's Avatar
insight?
cb
Ive seen the ecu boost beat much worse downlow, its not as bad on this car, thats why i said that. this will illustrate why its impossible for the ecu boost to do what the truboost did.
Notice the area highlighted? Notice how its spooling quicker? well it takes that momentum from that additional earlier spool and thats where the torque is coming from. It doesn't look like much on paper, but get in a car and test it for yourself.. its a very big difference in seat time (atleast it was in my car). and not on the dyno.. on the street.
ecu boost gives you a smooth transition with torque, where as other controllers hit more brutal and harder. I can see ecu boost being fine for stock blocks since its helping control torque and boost in general, but for a built engine ill never recommend it ever again.
If there's something anyone wants me to test on Chucks car let me know.. ill do more testing with the 3 port if you want it done, just pm me what you want me to do to it and ill do it.
We are not keeping the torque this high though. He wants it under 400tq.
But ya.. I can make the curve flat, go up, go down, etc.. theres lots of control with ecu boost.. if the spool can be corrected to work properly ill run it on my car, until then i refuse to lose low end response on a high dollar setup just because of a $100 boost controller.
Old Jun 8, 2011 | 12:59 PM
  #89
Boosted Tuning's Avatar
First, when using a MBC, you still get the "boost cut" safety feature. Those other features dont matter that much, except for the map switching if you use two fuels alot.
Next, I have a LOT of experience with ECU boost. I wrote the how to's on it and have tuned many cars on it. I can say without a doubt, that a MBC spools faster and is more consistent.
Old Jun 8, 2011 | 01:00 PM
  #90
CBRD's Avatar
Yeah- this argument is going in circles-
I disagree- and have seen the opposite here in testing-
and ecu boost offers things you simply cant- and for more than straight line drag or street driving-
throttle based boost (the best on a track car)
correction, multiple maps- etc...
we will have to agree to disagree
Cheers
CB
thanks for helping a bbk client though.
